Author: Subject: Cruising rpm - CBR1000F BEC
Edwardo
posted on 6/4/20 at 08:40 PM Reply With Quote
Evening all,
Finally got my first drive of the CBR1000F powered Locost on Sunday (brief trip to Aldi and back).
The acceleration is phenomenal compared to what Im used to driving - and even started to get used to the massive clunks/crashes up and down through the gears towards the end.
On the way back however, I took the short hop down the dual carriageway. I was told when buying it that it was 5 speed - which was very suspect as all research suggested that it only ever came with a 6 speed box. Very quickly I ran out of gears and didn't seem to be going very fast compared to the screaming from the exhaust and the vibration through the chassis.
After checking the spare engine I recently bought which had 6 gears marked on the casing, I got underneath and checked again. It looks like some previous owning so-and-so has ground off the 6 from the outer casing presumably due to losing 6th at some point and not wanting to strip it down and fix! So until I replace the motor in the winter Im stuck with 5 gears
My calcs and the gear calculator sheet in this area have basically come out the same at 60mph which is nothing - Im turning approx. 7300rpm which seemed about right from memory of Sundays run. Bearing in mind 60 is a fairly common sensible speed for a car, Im looking for ways of making it more liveable with.
The silencer is not in the best of nick and had the DB killer removed so that wouldnt have helped. So Ive today ordered a long repackable Wunoff jobbie that they are running an offer on which should help.
Is there anything else I can do in the mean time to make it a bit more liveable with? Ive looked at a lower diff ratio (3.5) which might be an option for the winter rebuild. Does anyone have any experience with this does it help a lot?
Tony
hobbsy
posted on 6/4/20 at 09:41 PM Reply With Quote
Not really many other options other than bigger diameter rear tyres?
TimC
posted on 6/4/20 at 10:04 PM Reply With Quote
3.54 will help significantly.
I suspect that what you really want is https://www.retroford.co.uk/product/3-31-english-crown-wheel-and-pinion-cwp-3-3/
And a 6th gear obviously.
ian locostzx9rc2
posted on 7/4/20 at 06:32 AM Reply With Quote
Not the same engine gearbox but my zx9r powered striker was running a 3.64 Sierra diff and 185/60/14 tyres in sixth gear mph per 1000 revs was 10.3 mph it topped out at 12000 revs which was 124mph if I could of changed it to a 3.1 approx diff it would make it a lot better on motorway runs it was fun and very rapid
Edwardo
posted on 7/4/20 at 06:16 PM Reply With Quote
Thanks for the replies all - I realise that BEC's are far from relaxing at higher speeds when compared to a CEC - but it just seemed far too much - and now makes a bit more sense.
I did briefly think about larger wheels - but the circumference of a 195/50/15" is exactly the same as the 205/60/13's I have on now so wouldn't gain anything. I personally think 7's look out of proportion with anything larger than 15's anyway (no offence intended to anyone who has btw).
The gear ratio calculator on here has the exact engine in the drop down list and shows it topping out at 100mph flat even if I had a 6th - so I think further work definitely required here. Thanks for the link to 3:3 diff ratio too. I guess this is about as low as they go without losing too much acceleration?
It certainly explains why I was taken on the route I was on the test drive. Redditch has a big ring road which is fast in a lot of places so I was surprised when we didn't go near it. Again, makes sense now..... Oh well, better start saving some penny's!
Cheers again
Tony
ReMan
posted on 7/4/20 at 06:20 PM Reply With Quote
There's a possibility that you either have a CB1000F engine or gearbox, which would be a 5
speed, I believe that they were all but identical otherwise.
I wouldn't wait till winter though, it shouldn't take more than a day on your own to swap an engine, you cant drive not at the =moment anyway.
Better than hating it till then
[Edited on 7/4/20 by ReMan]
www.plusnine.co.uk
∙،. ˘≈ﺣ
View User's Profile Visit User's Homepage View All Posts By User U2U Member   ReMan 's ICQ status
Edwardo
posted on 7/4/20 at 06:59 PM Reply With Quote
It is definitely a CBR1000F engine. I've got the CBR1000F Haynes manual here and it shows a 6 speed for every single variant (even the 600). They just didn't make this bike with a 5 speed it seems.
The only concern about doing the engine swap now is that the spare engine was an Ebay purchase (so condition to be taken with a pinch of salt lol). I've not had time to look it over properly (check compression etc). The other sticking point is that the spare engine seems to be an 88 as opposed to the 93 that's in it. When I bought it I was told it was a 91 - which would have been the same. There are very slight differences for the 87 & 88 engines compared to the rest including the carbs which are not all 4 straight in-line like they are on the 93. On the 87-88 models 2 carbs sit inline and then there is a slight bend then the other 2 are inline (so it's like a V shape). So I'd have to check if I can use the carbs/mounting collars of the one in the car to see if they will physically connect to the older motor. The carbs that came with the 88 engine haven't been touched for years by the looks of it. If I had to use them they would have to be sent off for Ultrasonic cleaning and get a rebuild kit to make sure they were ok.
It's a real shame - the motor that's in it starts/run and pulls superbly! Damn that pesky missing gear
Tony
ReMan
posted on 7/4/20 at 07:10 PM Reply With Quote
Why not just split the spare and swap the gearbox then?
www.plusnine.co.uk
∙،. ˘≈ﺣ
Edwardo
posted on 7/4/20 at 07:14 PM Reply With Quote
I'm concerned I'd mess it up royally and then have 2 useless engines
Edwardo
posted on 7/4/20 at 08:26 PM Reply With Quote
You got me thinking more seriously about the engine swap ReMan! So I just went out and did a proper check/measure up etc to see what it would take.
It actually looks like the carbs/rubbers that I've got on now will fit the earlier model! The ports on the head of both are angled (V shaped slightly) when looking from above - it just seems that the rubbers on the later models take out the angle so the later carbs can sit straight
Apart from the head water outlet hoses connection points being in a slightly different position (which a new length of silicon hose would sort) - everything else "seems" to be a straight swap
Gotta be worth a punt to swap it out and try it I reckon even if it is a couple of weekends work - so will give it a go.
Thanks again everyone
Edwardo
posted on 29/4/20 at 09:58 PM Reply With Quote
Just a slight update,
I've got the existing SC24 engine with the missing 6th gear out and on the floor (was an interesting fight with the prop adaptor bolts) - and the older SC21 replacement engine next to it on the trolley:-
I've replaced the 7 tooth trigger wheel ignition and 2 coil pickup of the older SC21 engine with the later 9 tooth trigger wheel ignition and single coil pickup of the later SC24 engine that was in the car - so that it will work with the wiring and ECU fitted on the car already.
I've also got the smaller 19mm silicone hose for the outputs from the head into an adaptor to connect back into the exiting 25mm hose to the rad.
Just got an issue with a couple of the exhaust studs to sort out and it should be ready for dropping in hopefully.
Whilst I was waiting - I thought it best to check what diff I have fitted - and have to say it's got me totally stumped!
I was expecting to have to turn the propshaft nearly 4 times to see the rear wheel rotate once, this would be a standard 3.89 ratio as I understand it?
I am totally confused though as 1 full turn of the prop only moved the rear wheel just over half a turn??? I got my son to check whilst I was turning the rear wheel and he said the prop mark came round twice when I had only turned the wheel 1 1/7th turns?
I have had a couple of beers and might not be thinking straight - but summat doesn't line up here does it? I thought the other rear wheel might need stopping from turning to check properly - so chocked that and repeated - but got the same result?
Anyone with a clear head help me out here lol?
Tony
adithorp
posted on 29/4/20 at 10:18 PM Reply With Quote
If you're only turning one wheel it'll half the ratio. So for a 3.89:1, one turn of the wheel will only require 1.95 turns of the input.
http://jpsc.org.uk/forum/
Edwardo
posted on 29/4/20 at 10:56 PM Reply With Quote
Ahhh, ok that makes more sense then. So it looks like I do have a 'standard' escort diff then as 1 wheel rev was slightly less than 2 prop rotations?
Thanks for the help - much appreciated!👍
adithorp
posted on 30/4/20 at 04:03 PM Reply With Quote
Does sound like that. To a more accurate result, turn the wheel 10 turns while counting input turns. Double input turns and divide by 10 to get your ratio. Be sure the other wheel can't turn.
Shandylegs
posted on 30/4/20 at 06:20 PM Reply With Quote
Hi - Have you tried running the figures through the speed calculator at the top of the bec section.
Unfortunately the CBR1000F engine will always be at a disadvantage due to the high primary drive ratio. Even with a 3.11 diff fitted (which you dont have the option of with a live axle car), mine would max out circa 105-110mph meaning cruising speeds were always quite high.
Cheers......
Edwardo
posted on 30/4/20 at 09:40 PM Reply With Quote
Hi Shandylegs - Thanks for the reply. It's nice to hear from someone who has had the same engine in a kit. What car was yours in?
Yes I've run the different options through the speed calculator so I realise it's never going to be a comfortable cruiser I just don't want my ears to be bleeding and my teeth vibrating out of the gums at 65-70 really.
TimC posted a link to a 3.3:1 gear set for the English diff which looks like as low as it goes for a live axle car. Popping that into the calculator gives approx 115 top speed at max revs.
That seems to suggest 80mph (which is probably the most this car would be taken to in all honesty) is approx 70% of the rev range. The CBR1000F revs to approx 10500 so 70% of that would be approx 7350rpm - which I could hopefully just about stand.
If I leave the current 3.89 diff in - top speed is approx 100mph according to the calculator. So 80% of the rev range would be 8400rpm which is probably a bit much for 'cruising'?
I'll continue with the engine change and get 6th gear back for now. Hopefully that along with the brand new Wunoff silencer will hopefully tame it enough for now.
I've got some 'interesting' findings from the engine that I took out - will post some pics at the weekend hopefully
Cheers again
Tony
