Author: Subject: Formular 27 rear bushes
Tigg
posted on 25/5/20 at 10:04 PM Reply With Quote
Hello all. New here. Have had a formally 27 chassis for a bit and think I finally have in mind what I would like to do. I bought the chassis already built with suspension arms complete but not bolted up. My question is what bushes will I need for the rear arms to chassis mount. The "eye" of the arm is 40mm long with an internal diameter of 25mm. The arm fits snugly into the mounting point so no room for top hat style. It will need to be a straight bush. Also do I need to use camber correcting bolts, it seems like a difficult way to set things up if I need to screw the rose joints in and out. Thanks in advance for anyone that could help. Kind regards Kevin
