Author: Subject: Front suspension
planetester
posted on 27/5/20 at 04:37 PM Reply With Quote
Front suspension
I may be asking for a lot of help in the coming months, has anybody got a decent picture of a locost front suspension, Arms, Pivots, coilovers, track rods that has recently passed the IVA, in the 10 years ive been away lots of things have change, was going to use hoses and shrink sleeving but that has been outlawed.
thanks in advance
coyoteboy
posted on 27/5/20 at 04:42 PM Reply With Quote
Hoses and shrink sleeving for what?!
Report your local potholes, it actually works!
planetester
posted on 27/5/20 at 05:09 PM Reply With Quote
Track rod ends
russbost
posted on 27/5/20 at 06:21 PM Reply With Quote
Not worth faffing with anything else when this sort of thing is readily available for peanuts
Linky
Furore Formula Car - the only two seater modern Formula Car lookalike. I no longer run Furore Products or Furore Cars Ltd, but would still highly recommend them for Acewell dashes, projector headlights, dominator headlights, indicators, mirrors etc, best prices in the UK! Take a look at http://www.furoreproducts.co.uk/ or find more parts on Ebay, user names furoreltd & furoreproducts, discounts available for LCB users.
View User's Profile E-Mail User Visit User's Homepage View All Posts By User U2U Member   russbost 's Aim
Deckman001
posted on 27/5/20 at 09:07 PM Reply With Quote
You can just about see the track rod ends covered by what Russ says
Jason
SteveWalker
posted on 27/5/20 at 10:23 PM Reply With Quote
Linky
But worth looking elsewhere, they are just cable gland shrouds. From memory, 20S is about 26mm ID and are available for just 2.99 for a pair, plus the unneeded glands from Screwfix - Linky There are tables of gland sizes and nut dimensions available for checking online.
Which of course you can pick up within an hour or so as click-and-collect if you have a local store.
[Edited on 27/5/20 by SteveWalker]
planetester
posted on 28/5/20 at 09:16 AM Reply With Quote
Thanks, ordered
Looking at the IVA manual section 16(Exterior projections) Fig 5 page 10, does it mean the bottom of the coilovers and adjuster dont need protecting
russbost
posted on 28/5/20 at 12:17 PM Reply With Quote
Originally posted by planetester
Thanks, ordered
Anything which is enclosed between the A/V section of the upper & lower wishbones is exempt from the sharp edge test
G13BLocost
posted on 28/5/20 at 07:07 PM Reply With Quote
What do you mean by outlawed? I had planned on using a few layers of thick heat shrink to smooth out my tierod joints. Anything official on this?
Between Building Robots, Building Cars, Playing D&D and Walking Dogs, I have no time at all!
Long time car builder and ex-F1 engineer; no silly questions please.
russbost
posted on 28/5/20 at 07:17 PM Reply With Quote
Anything protecting a sharp edge must be "durable, serviceable & permanent" heat shrink fails on the serviceable part as when you asjust tracking it will get knackered & to replace you'd need to remove the TRE, hence many folks would just leave it off, whereas with the cable dhrouds you can slide back & re cable tie after adjustment
G13BLocost
posted on 28/5/20 at 07:48 PM Reply With Quote
That sucks. Given that it's going all fall off on the trailer ride home...
planetester
posted on 29/5/20 at 11:49 AM Reply With Quote
Thanks for the answers, I'm much happier now
