Author: Subject: Painting mild steel without primer
posted on 31/5/20 at 06:56 PM Reply With Quote
I've built myself a rocket stove using mild steel. It gets hot as you burn wood in it. I'd like to paint it with high temperature paint to help prevent rust, but will it paint without primer first or if I need primer can you suggest a high temp primer?
Nick
[Edited on 31/5/20 by nick205]
r1_pete
posted on 31/5/20 at 08:01 PM Reply With Quote
VHT do a high temp primer, withstands just short of 1100 C.
posted on 1/6/20 at 06:46 AM Reply With Quote
Thanks, will take a look.
Bluemoon
posted on 1/6/20 at 07:26 AM Reply With Quote
used VHT high temp paint on mild steal exhaust. Works ok, prep well and mist coat for primer..
View User's Profile View All Posts By User U2U Member   Bluemoon 's Yahoo
posted on 1/6/20 at 08:26 AM Reply With Quote
Thanks again, useful to know.
In the past (for non heat applications) I've used red oxide aerosol or brush-on primer. It's always done me very well and it's cheap to but and use as well. I just can't see that working for higher heat applications, hence my question. I'm going to investigate the VHT primers and give it a dust coat with as suggested.
Having to be back in the office will have its benefits, but it'll also seem a bit constricting in some ways!
Bluemoon
posted on 1/6/20 at 08:30 AM Reply With Quote
Was not clear. The VHT heat resistance paint I have used didn't need a primer, they recommended mist coat (of the topcoat).
Dan
posted on 1/6/20 at 09:38 AM Reply With Quote
Dan
OK - thanks for clarifying. That's the type of info/experience I was looking for.
posted on 1/6/20 at 09:59 AM Reply With Quote
Same experience with VHT paint - clean the bare steel as well as you can, a few light coats, then heat the thing up. In my case, it was my exhaust system so I ran the engine until the exhaust was hot.
The paint doesn't stick very well until the metal has got hot - I think it bonds during the heating phase. I don't know if a blowtorch would do the job...
The older I get, the better I was...
posted on 1/6/20 at 11:18 AM Reply With Quote
Thanks again.
I guess I'll give it a few light coats then burn some wood in it to get it good and hot.
posted on 1/6/20 at 01:18 PM Reply With Quote
Bought some high temp "primerless" satin aerosol to paint the rocket stove with. Will concentrate on getting the steel as clean as I can before painting and following manufacturers instructions for best curing etc.
Photos to follow when it's painted!
