Author: Subject: Replacement Bearings
Schrodinger
posted on 5/6/20 at 12:13 PM Reply With Quote
I ride an Orange Five and the swing arm bearings do not last very long, one reason for this could be that they are only required to travel through about a max of 20 degrees rather than rotating. Are there any bearings that are meant to be used like this that I could try? The current ones are marked 6902 2RS.
Any thoughts gratefully received.
Keith
cliftyhanger
posted on 5/6/20 at 01:04 PM Reply With Quote
How much are you paying for the bearings?
I see they are available for 2.99, don't expect much for that!
SKF on fleabay about 11 a pop, they should have a better life. But many bearings are only smaller movement, yours may suffer with dirt etc too?
EDIT go to china and 10 bearings for a fiver! could explain a lot. Especially the 2.99 ones.
[Edited on 5/6/20 by cliftyhanger]
Schrodinger
posted on 5/6/20 at 01:09 PM Reply With Quote
Just paid 25 for two Zen 6902 2RS bearings from Orange with new end caps and screws which I didn't need
Keith
coyoteboy
posted on 5/6/20 at 01:17 PM Reply With Quote
I was able to put together replacement bearing kits for my old NRS2 frame for about ~7 a set, the official pack was 50.
RBBs don't like oscillatory motion but that's compounded by the poor environment and likely heavy loading. This isn't a bearing quality issue, it's a bearing design use issue - it's a disposable part in this operation.
Technically bushes are better from a lifespan perspective, but higher friction.
Just find a cheap source of 2RS bearings and replace them often - no point paying for expensive bearings, or repacking them with grease, all a waste of time. Stick to a 6 month replacement schedule on cheapos and you'll be very happy.
Yours are currently 3.50+VAT each on simplybearings. Why waste more than that - you may get an extra 3months from set that cost twice as much, do you care?
I have the same issue with bottom bracket Bearings - if I'm lucky I get 12 months from an OEM set, I just bulk buy and replace more regularly.
[Edited on 5/6/20 by coyoteboy]
Report your local potholes, it actually works!
Daf
posted on 5/6/20 at 01:24 PM Reply With Quote
I used to ride a specialised FSR and was going through bearings every few months, the brand and packing them with grease made next to no difference in life.
I then changed the bike to a Merida which has caps over the top of the bearings and in 4 years of regular trail riding I've never replaced a bearing.
My conclusion is buy cheap bearings and replace them regularly.
Schrodinger
posted on 5/6/20 at 01:40 PM Reply With Quote
Thanks for you thoughts.
I will look to get some sets of bearings for the swing arm and bottom bracket and replace them rather than buying from the bike manufacturer.
Keith
