Author: Subject: Side panel fitting short/long
MBrown
posted on 22/6/20 at 07:44 PM Reply With Quote
Hi all,
I'm in the process of attaching some bodywork, and was just wondering if there are any additional concerns to be aware of regarding IVA etc with the side panels if I decide to cut them short for easier fitting like in the below picture. I would prefer the look of keeping them long and cutting out suspension holes etc but I prefer to cut them short for ease of access, maintenance, replacement. I will probably keep the pieces I cut off so I could always add these superately later if I really do want to cover up the hole but so far I'm not too bothered. I understand I might have to put some rubber trim along the leading edge of the fiberglass even if that's just to protect it/make it neater.
Thank you all
[Edited on 22/6/20 by MBrown]
roadrunner
posted on 23/6/20 at 05:31 AM Reply With Quote
just make sure your sharp edges are covered.
jacko
posted on 24/6/20 at 08:00 PM Reply With Quote
It's a long time since I made my car for sva but when Iva came in you had to have long sides up to the nose cone
Unless some one knows different
Jacko
MBrown
posted on 24/6/20 at 08:15 PM Reply With Quote
Thank you for the replies all, I think I might do it in two parts - I'll cut them short but save the end and then cut holes/fit the suspension through at a later date if required, thanks all
jps
posted on 24/6/20 at 08:24 PM Reply With Quote
Jacko
Given you can put an Ariel Atom type vehicle through IVA I would think you can get away with not having side panels up to the nosecone... But presumably it is an easy way of solving the problem of applying necessary radii, etc...
907
posted on 25/6/20 at 09:40 AM Reply With Quote
Trouble is that "later dates" never come.
This is a classic use of CAD. ( Cardboard Aided Design )
Paul G
