Author: Subject: Speedo cable
jamrogers
posted on 4/7/20 at 06:42 PM Reply With Quote
Speedo cable
My Speedo cable has stopped turning, Iím guessing the cable has snapped and itís nothing more serious, does anyone know if a standard Sierra cable will fit it? I have a type 9 gearbox and tigers mechanical Speedo
build diary http://jamstigeravon.blogspot.com/
YouTube
https://youtu.be/JwwwilUd5Zo
snapper
posted on 4/7/20 at 09:35 PM Reply With Quote
More likely to be the square end gone round.
Yes Sierra will fir
I eat to survive
I drink to forget
cliftyhanger
posted on 5/7/20 at 09:26 AM Reply With Quote
I would be checking the speedo drive in the box is turning.
I had the odd situation where the speedo drive gear on the output shaft slipped and so that did 2 things. Firstly no drive, secondly stripped the plastic drivegear. Solved by some bearing lock andmanaging to slide the gear back, and a spare plastic drive. Worth a check while you are in there.
