Author: Subject: ZX10R starts sort of.
roadrunner
posted on 6/7/20 at 03:30 PM Reply With Quote
Got my regulator sorted and all plumbed in.
Engine starts and seems to run but noticed that it shakes slightly.
Turns out that it's only firing on cylinders 2 and 3.
1 and 4 primary pipes stay stone cold.
I have a spark to 1 and 4 and the plugs seem wet from fuel but I'm at a loss why they don't fire.
Any ideas I could look for.
Regards
Brad
steve m
posted on 6/7/20 at 05:15 PM Reply With Quote
Swop the leads on 1 and 4, ?
and try again
steve
adithorp
posted on 6/7/20 at 06:13 PM Reply With Quote
Is it individual coil on plug or twin coil packs feeding 2cylinders each? Do you have sparks on 1+4?
http://jpsc.org.uk/forum/
roadrunner
posted on 6/7/20 at 06:33 PM Reply With Quote
Thanks fellas.
Because of the layout of the loom its difficult to get them wrong way round.
There are 4 coils like in all modern engines and there is a spark on those that are not firing.
adithorp
posted on 6/7/20 at 08:03 PM Reply With Quote
Try listening for the injectors operating with a screw driver. You should hear a click.
roadrunner
posted on 6/7/20 at 09:44 PM Reply With Quote
I guess you rest the driver on the injectors as they operate.
adithorp
posted on 7/7/20 at 06:37 AM Reply With Quote
Yes. A long thin screwdriver is best. Rest the tip on what you want to listen to and the handle against your ear.
russbost
posted on 7/7/20 at 07:32 AM Reply With Quote
before spending loads of time on anything else I would try swapping the plugs from 2 & 3 with the ones from 1 & 4. If it's anything like other modern bike engines, if it's fouled the plugs it won't "unfoul" them. Would be very odd to have spark on all 4 & injectors only working on 2, plus you say plugs look wet, so sounds like it's getting fuel
Furore Formula Car - the only two seater modern Formula Car lookalike. I no longer run Furore Products or Furore Cars Ltd, but would still highly recommend them for Acewell dashes, projector headlights, dominator headlights, indicators, mirrors etc, best prices in the UK! Take a look at http://www.furoreproducts.co.uk/ or find more parts on Ebay, user names furoreltd & furoreproducts, discounts available for LCB users.
View User's Profile E-Mail User Visit User's Homepage View All Posts By User U2U Member   russbost 's Aim
roadrunner
posted on 7/7/20 at 01:07 PM Reply With Quote
Hi Russ.
I have tried different spark plugs.
I will try swapping plugs and coils though.
roadrunner
posted on 19/7/20 at 04:50 PM Reply With Quote
Hi fellas.
It now runs in all 4 cylinders.
I ended up taking the injectors out. Tested 1 that wasn't working, just put 12v through it alternating the current then swapped them over. At this point I had achieved 3 cylinders firing.
Took out the last one, put 12v through it and it seemed to be stuck. After a few swapping around of the current it started working.
All back together and working fine.
Thanks all.
adithorp
posted on 19/7/20 at 05:06 PM Reply With Quote
Wayhay!
Might be worth sticking some injector cleaner in the fuel just to get rid of any residual lacquer. Forte is good or Wynns if you can't get.
roadrunner
posted on 19/7/20 at 05:41 PM Reply With Quote
Already done that.;-)
