Author: Subject: Steering Column Shroud ?
Deckman001
posted on 10/7/20 at 04:51 PM Reply With Quote
Hi all,
I have decided to not use the Std Sierra shroud as it doesn't look good due to not covering the top of the column and exposes the wiring to the std switches I'm using.
What have other people used to cover this, or have I a fundamental mistake with my car ?
Jason
steve m
posted on 10/7/20 at 05:06 PM Reply With Quote
Mine Jason, was a baked been tin, covered in green vinyl
steve
Deckman001
posted on 10/7/20 at 05:17 PM Reply With Quote
Hmmmm, interesting idea Steve, I thought about plastic plant pots, but had thrown all of ours out during lock-down tidying so will have to buy some more plants if i choose that idea
Jason
J666AYP
posted on 10/7/20 at 09:34 PM Reply With Quote
I used a guttering connector on mine, could probably cut slits into one and slide over the stalks. Plus they are less than a quid each.
J
[Edited on 10/7/20 by J666AYP]
posted on 12/7/20 at 09:43 AM Reply With Quote
Jason,
I had the same "top gap" issue between the Sierra shroud and my dash when building my MK Indy. I used the Sierra shroud and covered the gap with a bit of formed Ally sheet covered in black vinyl. If you look in my photo archive you'll find a photo.
[Edited on 12/7/20 by nick205]
CosKev3
posted on 12/7/20 at 10:42 AM Reply With Quote
Rare and expensive now for unbroken sierra ones
MikeR
posted on 12/7/20 at 02:01 PM Reply With Quote
I haven't made mine, but I have a bright pink vanish tub which looks the correct size
Deckman001
posted on 12/7/20 at 05:53 PM Reply With Quote
Cheers for the reply guys, I still have the original Sierra ones so just adding a sleeve might be a good idea, although am not sure i want to re-do my dash to incorporate it nicely But I think I might give that a go
Jason
joneh
posted on 13/7/20 at 08:34 AM Reply With Quote
I found a baby milk tin was the right size. Looked good when wrapped in vinyl due to the ridges but then I gave up when I sourced a Sierra one.
posted on 13/7/20 at 08:51 AM Reply With Quote
Jason
For rference, I didn't "redo" the dash I'd made myself from plywood. The shroud "extra" is simply a section of Ally sheet metal formed slowly by hand into a U shape. I then used aerosol carpet glue to stick on black vinyl to match the dash. Either side of the U shape there are small black self-tapping screws used to secure it to the Sierra plastic shroud. The solution isn't jet-wash proof, but covered the gap and looked fine IMHO. From the drivers seat you couldn't really see it either.
Deckman001
posted on 13/7/20 at 01:06 PM Reply With Quote
Jason
Ohhh, that's even easier, well it's your fault i was mistaken, you did such a good job on yours, it looked like it was a work of art !!
Jason
tims31
posted on 14/7/20 at 11:05 AM Reply With Quote
I made one out of ali sheet bent to shape and covered with vinyl but my recent post on 3D printers has got me thinking about printing one if possible.
Build: http://www.martinsfurybuild.co.uk/
