paulf
posted on 28/1/05 at 10:55 PM |
Sierra fuel injection ecu .
I was talking about fuel injection to someone at work today and he suggested using a sierra ECU and remaping it.I replied that as far as i was aware
it wasnt possible to remap one.He then told me that he once had a 91 k plate sierra that failed MOT on emissions and to get around it the garage
adjusted the fuelling by remapping the ecu which was a Bosch unit.
If this is possible it may be another cheap alternative to megasquirt.Does anyone know if this is possible and if so where the software could be
obtained from?
Paul.
Mark Allanson
posted on 28/1/05 at 11:03 PM |
If it is a pinto ECU, I don't think it can be remapped. I have heard of fitting a potentiometer between 3 of the wires to alter the mixture at
different throttle settings to increase power - never could find out which wires though!
paulf
posted on 28/1/05 at 11:24 PM |
It was a 2000 dohc , the pot idea sounds like the ebay scams to me.I once read an article in a kit car mag about a company that remaps ecus and they
were using citroen or puegot ones if i remember correctly, i think these would be motronic units.
If it is possible to get software it must be possible to do with the more basic units that are just fuel and ignition ecus in the same way as they can
be chipped.
Paul.
posted on 28/1/05 at 11:37 PM |
Many ECU have a trim facility to allow very minor adjustments to fueling at idle for emmisions -- not being a Ford person I haven't a
scooby about the Ford ecu.
In any case this is just a fine adjustment not remapping.
Mark Allanson
posted on 28/1/05 at 11:41 PM |
" -- not being a Ford person I haven't a scooby about the Ford ecu."
I though you were a ford expert?
CairB
posted on 29/1/05 at 09:28 AM |
Some of the schemes involve adjusting the signal of the temp sensor or air flow meter to kid the unit that the air is colder and denser / more air
flow so increase the fuel. I tried this on an EEC-IV with a circuit that gave a proportional signal. It was noticable at low rpm and small throttle
openings that the fuel was being increased. A small adjustment gave a rise in tckover, to much adjustment gave black smoke and 8 stroking the engine.
However no significant difference was noticed during driving. The problem with the kidding sensor approach is that the fueling algorithm as a whole
needs to be understood otherwise a worse overall compromise may result.
I would suggest considering a MegasquirtnSpark-Extra rather than trying to modify the standard unit as it will probably be cheaper, give you full
control and make available other features such as rev limiter, shift indicator etc.
Colin
jollygreengiant
posted on 29/1/05 at 10:23 AM |
obtained from?
Paul.
Dead Easy Job This. Unclip airflow meter, undo hose clip and invert airflow meter. carefully remove black plastic (square, wedge shape)cover. Then
screw shut adjuster fully (fully rich). Start engine. With gas sensor probe inserted into exhaust, turn large black wheel in housing (held by spring
wire) in appropriate (anti clock wise?) direction until CO reads about 6.0. adjust mixture screw now to give CO reading about 0.5. Remove traces of
old silicone sealer from cover, apply new sealer and refit cover and refit airflow meter. JOB DONE.
This fixes the most basic problem with the Efi system that ford used. The clock work spring goes week and it needs re-tensioning. As above. Dead
easy.
Enjoy.
paulf
posted on 29/1/05 at 11:20 PM |
I realise that the mixture can be tweaked in a number of ways but was thinking more of completely remapping from scratch as would be done with a
megasquirt.
My mate at work reckons they used a lap top and had the software on a CD.
There must be everything in the ecu to do the job required if it is posssible to remap from scratch. It seemed a good idea to be able to use a
standard ecu available from a scrappy , but it looks as if i will be using a Megasquirt.
Paul.
posted on 30/1/05 at 02:18 PM |
Not a Ford fan at all but having I know my way around just about any Ford built between the 1172 side valve and the CVH after that my knowledge is
minimal.
Rob Allison
posted on 31/1/05 at 10:42 AM |
It is possible to remap the ecu. But you will need to get the right model. You can get a programer from America that will allow you to change the main
map. But its complicated. I'll try to find the web site for you.
Rob Allison
posted on 31/1/05 at 11:01 AM |
Here is some of the tuning for the EEC iv and v.
http://www.eec-tuner.com/
http://www.vanaaken.com/europe/protuners/fordchiptuning.htm
http://www.mustang50magazine.com/techarticles/17682/
CairB
posted on 31/1/05 at 07:25 PM |
Rob,
Good links.
Here's another:
http://www.kvitek.com/ford/
I remember looking into this but was discouraged by not being able to find any information on the data format. It was mainly the American car versions
that have been decoded. From memory there was a do it yourself version that used a xilinx logic array. In the end I decided that a Megasquirt was the
easiest route and gives the opportunity for extra features to be built in.
Colin
paulf
posted on 31/1/05 at 10:12 PM |
Yes good links, I looked for some time yesterday but didnt find much usefull, however it seems that it is still easier and cheaper to use a megasquirt
unit.
Its a pity as it would be good to be able to mod a comercially made unit .
Paul.
quote: Originally posted by CairB
Rob,
Good links.
Here's another:
In the end I decided that a Megasquirt was the easiest route and gives the opportunity for extra features to be built in.
Colin
Rob Allison
posted on 3/2/05 at 12:41 AM |
I'm getting a MSnS to replace my EECiv. Going to use an old ECU, remove the plug and wire it for the Megasquirt. This is so i can do a plug and
play. Also the Ford wiring harness is neat, saves me making one up ![](/images//smilies/wink.gif)
