turnipfarmer
posted on 10/8/20 at 02:10 PM |
Brake Light Woes
Hi Folks...
I've done a search for this one but can't find anything.
It's a brake lights problem on a seven style. There's a combination light unit on each rear wing, with 4 wires for indicator, brake
light, tail light & an earth. Brake lights operate via a pressure switch. The loom is from PWS. Here's the situation...
Am getting 12v to the pressure switch. Also getting 12v from the pressure switch when brake pedal is pressed, but only 0.5v down the wires to the
brake lights themselves. Indicator & tail lights work OK though. It's the same on both sides. The wiring on one side is also completely
independent of the wiring on the other.
Replaced the pressure switch - no difference. Replaced all fuses - no difference. Brake light bulbs both OK.
Can't see what would affect both brake lights & nothing else. Before I start tearing the interior apart to check out every single inch of
the wiring, can anyone else think of anything else I might try first?
Got to be something obvious, but I just can't see it.
Thanks.
40inches
posted on 10/8/20 at 02:31 PM |
quote: Originally posted by turnipfarmer
Hi Folks...
Thanks.
Run a test wire from switch to light?
loggyboy
posted on 10/8/20 at 02:50 PM |
Try bypassing the pressure switch, or swapping for any type of press switch. They are notorious for not working due to air locks etc.
Mistral Motorsport
posted on 10/8/20 at 03:00 PM |
If I'm understanding right you've got a pressure switch in the rear brake hydraulic circuit?
If so I fitted this when building my MK Indy. The brake lights came on, but only when you gave the brakes quite a bit of effort (brake pedal quite a
push). If building again I'd use an electric switch at the brake pedal for better brake light response and better warning to drivers behind.
adithorp
posted on 10/8/20 at 03:27 PM |
Won't be the switch if you have good feed out of it (though they are a common fail). Must be an issue somewhere between there and the lights and
as you say both are the same then it must be before they split. Check the loom between the switch and where it splits to feed each side. My money is
on that splice/joint where it splits bring corroded.
http://jpsc.org.uk/forum/
steve m
posted on 10/8/20 at 03:42 PM |
Has it ever worked, or is this a new installation ?
If your only getting '5v at the bulb end, it must be shorting out some where?
posted on 10/8/20 at 06:44 PM |
Bad ground
adithorp
posted on 11/8/20 at 06:28 AM |
quote: Originally posted by britishtrident
Bad ground
Possibly and my initial thoughts but I'd have expected faults on other lights as well as they're combo lights with a shared earth.
turnipfarmer
posted on 11/8/20 at 01:44 PM |
Thanks for all the replies guys.
For your info...
I also discounted the earth for the same reason as above.
Bypassed the switch - still nothing.
Will try running a test wire from switch to light.
If that doesn't work then it's got to be between switch & lights, which means dashboard & instruments out. Ah well - just have to
bite that bullet if needs be
Lights have been working fine for last 6 years.
gremlin1234
posted on 11/8/20 at 02:40 PM |
the next test I would do:
use a meter, on the feed side of the switch, and check its 12v, then activate the switch, (or bridge with a screwdriver or similar) and see what
voltage is (ie read under load)
if its now significantly less than 12v the problem is before the switch,
if remains 12v, the problem is after that test point.
MikeR
posted on 11/8/20 at 09:39 PM |
I'd follow gremlin advice first, then run a test wire, then (whilst using the test wire) run a dedicated earth. Then use jumper wires to feed
12v into your temporary cable.
You've then tested the switch, feed to the switch, wire from switch to lights, earth from lights and the lights themselves.
Somewhere in that lot it should work and therefore you know what is failing.
Good luck
turnipfarmer
posted on 12/8/20 at 11:52 AM |
Now disassembled the dashboard & think I may have found the problem (hope so anyway!)
Did some more testing last night & noticed I wasn't always getting 12v on the output from the switch. This happened more & more
frequently until it dropped to 0v completely.
Then I noticed that the output wire colour was different at one end to what it was at the other. That can only mean I had to lengthen it at some time
in the past.
So there has to be a connector somewhere along the way that's hidden by cable sleeving, and if it's failed, it would account for the
problems I've been having.
Let's hope so, & once more thanks for your suggestions.
turnipfarmer
posted on 22/8/20 at 06:05 PM |
Let there be light - and there is - finally!!
After many more episodes of yes it's working! - No it isn't!, I've finally abandoned the idea of trying to identify this mysterious
fault, and just fixed the problem by wiring the output from the pressure switch straight to the brake lights.
Thanks to everyone for their kind help and suggestions.
