Author: Subject: AJ30/ST220 Oil take off plate
RWD Focus
posted on 29/8/20 at 04:29 PM Reply With Quote
Wanting an oil take off plate to fit the Jag/Ford V6 engine, M22x1.5mm thread to allow me to fit pipework up to my remote filter.
Have already modified standard Jag one but looks untidy, can't seem to find what I need online with correct thread.
Any ideas?
voucht
Contributor
Posts 229
Registered 22/5/11
Location 1
Member Is Offline
Photo Archive Go!
Building: Haynes roadster on the road since november 2014 bu
posted on 29/8/20 at 05:42 PM Reply With Quote
Check out Think Automotive
https://www.thinkauto.com/ acatalog/On_line_shop_Oil_Cooler_Take_Offs_38-p1.html
They have all kinds of take-off plates and 20x1.50 extension bolts.
Hope that will help
555
Oddified
posted on 29/8/20 at 07:11 PM Reply With Quote
I ended up machining up an adaptor sleeve m22x1.5mm to 3/4 unf and then used a standard Mocal remote oil take off.
Ian
big_wasa
posted on 30/8/20 at 06:49 AM Reply With Quote
I looked into it and then bought a jag housing. The only other way was going to be something custom.
RWD Focus
posted on 30/8/20 at 07:16 AM Reply With Quote
Thanks for all the suggestions.
Ian that was probably the route I was going to take if an off the shelf solution wasn't available.
Thank you
