Thanks guys! Powering into Episode 2 now. We did a TVR resto shortly before which we put an episode a week out on. Understandably we may not hit that
level of footage with this one but we hope to have some regular stuff on it!
- Muhammad Ali
Very entertaining, look forward to the next episodes
My build blog http://ianhaynes20.wordpress.com IVA passed 3/10/16
written off 23/9/18
Aug 2019 completed Tiger Avon with ST170 on TB's
Now restoring 1968 Ginetta G4
And - a series 1 Land Rover - don't ask why!
Photo Archive
Building: Ground up rebuild of a Robin Hood 2b for the IVA
posted on 10/9/20 at 02:16 PM
One thing I'd say watching that rather heart stopping vid is put a block of soft wood on your axle stand pad between it and the bodywork or
anything your else your lifting.
Metal on metal is very very slippery and there is no way I'd have went under the car as they had it there, worse still it was sitting at quite
an angle too and the front stands right at their full extent, barely touching the car! Not trying to be critical but I've had a few scares over
the years and cars fall faster than you can move out the way (and they don't always fall straight down either).
I know it's all very busy and exciting but just take a moment now and again, stand back and look at what your doing and think to yourself
"is that safe??" So please use wood next time and we might get to the final episode
Thanks so much to all for the replies, glad this will be of interest.
Mr Whippy, I would never baulk at a safety comment, as you say often its an unobserved issue that can catch you out. That is a very good point and
something I hadn't considered. Thank you for that, it will be remedied in future!
I used to know a guy who had his hand underneath a brake disc when the car came down so it was trapped between the disc and the concrete... that was
fun!
- Muhammad Ali
fun!
I bet. Sounds horrific!
We have all taken our eyes off the ball. I remember using an airgun to take a long bolt out from underneath a car, running the bolt out and the thread
acting against the gun and pinching my knuckles between the gun and the floor. Seems like such an unlikely thing to happen but there we go! Luckily it
was easily resolved by just gunning the bolt back in.
Personally, I don't use wood, but I always position axle stands under sill jacking points, or tow-bar - with a section narrow enough to fit in
the bottom of the cup, so that it is unable to slip sideways and (with jacking points) often slightly back from the rest of the sill seam, so they are
prevented from slipping sideways, or (with tow-bar) between mountings or bolts, that also prevent sideways slip.
Similarly, when jacking - under the ant-roll bar mounts (so they sit in the cup of the jack), under a tow-bar bolt, or under a some other (solid)
bracketry or bolt.
I have seen a car drop on someone's (my uncle's) arm many years ago, but that was a Fiat 126 and he just asked my Dad to lift it up a bit
Quick update, I have been very very busy between this build and all the other nonsense that comes with running a car channel on youtube. Those who
have subscribed will note that this isn't the only project I have on the go at the moment. FEAR NOT! It has not been forgotten, and this Friday
the next instalment goes live. Link for that can be found here:
In typical project style, most of this is covering the actual prep needed rather than any of the build, so we are getting our house in order and ready
for welding up a chassis. Few useful tips and we knock up the bench for welding here.
Photo Archive
Building: MK indy on the road: Simple airbox..
posted on 5/10/20 at 09:10 AM
fun!
Very easy to make a silly mistake, I do also know a local chap that was working under a landrover, lots of experiance DIYing on the vehicle yet one
day he was crush to death working under it on the drive leaving a young family.
Cars are fun but make be extra carefull when working under. When working on my donner I used axel stands and also shoved the wheels under just in
case. Once on 4 stands it's not stable as when haveing at least two or three chocked wheels on the ground.. I also prefere using ramps when
possible but can only do that with wheels on!
One of the first things I was taught as an appretice tractor mechanic in 1960 something was never put any part of yourself under a vehicle without TWO
means of support - one of those with cars was to put the wheel you have just taken off under the car - and that would make 3 means of support!
written off 23/9/18
I love this series of videos - but I am REALLY struggling with the accent sometimes! Of course, this is my problem, not yours... but you'd
think with a brother who lives in Dornock that I'd be better at understanding the accent by now!
Sorry dude. Believe it or not we do slow down the chat and try to speak clearer. Its usually worse than that!!
