Author: Subject: And another thing - Ford crossflow breather elbow for the inlet manifold
posted on 12/9/20 at 02:27 PM Reply With Quote
I now have a x-flow crankcase breather thingy - now I'm looking for the 90-degree connector for the Weber DGV inlet manifold.
Anyone have one they don't want, or know what it's called, and who would sell it?
Thanks.
The older I get, the better I was...
joneh
posted on 12/9/20 at 04:29 PM Reply With Quote
Thanks.
Got a picture? I've got the remains of a xflow here, less block, the breather thingy and inlet manifold and carb. Might have any other bits you need.
MikeR
posted on 12/9/20 at 04:57 PM Reply With Quote
Burton do them, the straight and 90 degree are quite cheap. You can also get them from anywhere (once I can remember the size). The 135 degree connector is stupid price.
posted on 12/9/20 at 06:23 PM Reply With Quote
I tried a search on Burton's website, but I failed due to not knowing the correct name...
MikeR
posted on 12/9/20 at 06:37 PM Reply With Quote
I found the expensive 135 degree which is out of stock but .... It tells you the fitting, so you can look elsewhere for straight or 90 as I can't find them on the site
https://www.burtonpower.com/vacuum-union-1-4npt-135-deg-elbow-fp472.html
steve m
posted on 12/9/20 at 07:14 PM Reply With Quote
David,
I made my breather connections using 15mm copper pipe fittings, when i was running the twin 40's
but discarded all of it, and just vented into a bottle, from the cam cover, and pop off valve
I never reconnected it when i went back to the 28/36 Dcd fire starter carb
steve
posted on 12/9/20 at 08:33 PM Reply With Quote
Here's the puppy, found for me by Joneh:
ebay
But there is NO WAY that I'm going to pay that money for it!
As I now know what they're called, I found that Burtons have this union that appears to be the right thing.
I'll check sizes tomorrow.
[Edited on 12/9/20 by David Jenkins]
MikeR
posted on 12/9/20 at 09:14 PM Reply With Quote
Sorry. I thought you were after the vacuum not water. Again, I'd but it from a hose supplier of Burton don't have it. I've got a spare in the garage. I can look who supplied it if you need a supplier name.
steve m
posted on 13/9/20 at 07:11 AM Reply With Quote
Its the same thread as a brass plumbing thread, and thats what i used, with a crimp and nut with a piece of 15mm pipe,
then normal heating hose to the top of the water pump,
steve
posted on 13/9/20 at 10:11 AM Reply With Quote
David, I might have a straight one if thatís any help? Iím away for a couple of weeks though.
MikeR
posted on 15/9/20 at 09:06 AM Reply With Quote
Found the burton ones for reference,
p45 of the 2020 catalogue.
FP477 straight 3/8 NPT (billet machined) £9.95
FP478 90 degree elbow 3/8 NPT £7.90
FP479 135 degree elbow 3/8 NPT £51.60 (no thats not a typo)
Also Vaccum take off
FSECFTU10 Straight 1/4 BSPF £3.25
All prices include VAT at 20%
posted on 15/9/20 at 12:56 PM Reply With Quote
Thanks MikeR - but I had found those (see my previous post).
...but the kind thought is appreciated!
