Author: Subject: MK Indy bonnet
adampage
posted on 11/10/20 at 03:15 PM Reply With Quote
MK Indy bonnet
In green, with 6 louvres / vents fitted and a large oval opening top front left, possibly fitted on a car with a turbo?
It was originally yellow judging by the fibreglass underneath.
It's not the most beautiful thing, so i'd only want £20, no idea if it would post, it would be entirely at your risk.
I'm in Stone, Staffs, to collect/meet, if you leave me a u2u.
Ad
Craigib76
posted on 11/10/20 at 08:17 PM Reply With Quote
Bonnet
Hi there can I have the dimensions of the bonnet please
Regards Craig
adampage
posted on 11/10/20 at 09:31 PM Reply With Quote
I'll measure up in the morning :)
Ad
adampage
posted on 12/10/20 at 03:54 PM Reply With Quote
Bit tricky...
Hey Craig,
It's a bit tricky to measure exactly as it flexes slightly depending on how it's sitting, and it's not fully mounted up yet and i don't have the nosecone on to compare it to, so might need to be slightly flexible with the numbers here, but here goes.
It's 34.5" long.
Freestanding - it's about 28" wide at the front, 40.5" at the back edge, but it splays out slightly when you stand it up, under its own weight.
If you measure the chassis where it sits, it's more like 26" at the front and 36.5" at the back, and it curves round to sit at this narrower width ok
Or to put it another way, if you try to measure around the curve, at the back edge (so the length around the top of the scuttle where it'll sit) that was about 48-49", but a bit hard to measure.
Does that make sense? Let me know if you need anything else.
Ad
adampage
posted on 12/10/20 at 04:01 PM Reply With Quote
Forgot to say
I'm 99% sure it's a genuine MK Indy bonnet, so whatever standard size for MKs are.
Also, it has about a 1" return on most of the length of each edge.
Ad
Craigib76
posted on 12/10/20 at 09:09 PM Reply With Quote
Hi there thanks for the measurements it appears to be too big for my formula 27
Sorry
Regards Craig
adampage
posted on 13/10/20 at 06:21 AM Reply With Quote
No worries
Thanks for letting me know
Ad
kennyl87
posted on 26/10/20 at 09:10 PM Reply With Quote
do you still have this?
adampage
posted on 26/10/20 at 09:23 PM Reply With Quote
Yes I do
Hi Kenny
Yes I still have the bonnet, is it of any use? If you send your email address I can send photos.
Ad
kennyl87
posted on 27/10/20 at 12:01 AM Reply With Quote
thanks Adam for the reply.
I'm pretty sure i can make it work. ill send the email address over.
Thanks kenny
adampage
posted on 2/11/20 at 09:26 AM Reply With Quote
Sold, paid and collected :)
Thanks Kenny!
