Author: Subject: GRP seat with some pads
adampage
posted on 11/10/20 at 03:34 PM Reply With Quote
Black GRP seat for Seven/Indy etc.
Feels solid, it has rubber trim on the outside edges & top, has seatbelt holes at the shoulder, it has one pad low down and one for the back of your head, and i might have the other pads, will look in the garage.
Sizes
- Base is 15" outside
- Hips 16" outside
- Shoulders 16.5" outside
- Front edge 16.5" outside
- Thighs and Chest about 14" inside width
- Height 33"
- Base 20" long (front edge to bum) outside
- Front of base to vertical line down from back of head (i.e. full length) 26"
So it would fit in a channel about 16.5" wide, but only just. The base is contoured, but has a small flat pad in each corner, so you could mount it on a flat plate, if you see what I mean.
It's had the very bottom rear corner (i.e. under edge of bum) on each side, assume to fit in a small space, but the holes are only about 2" across, so doesn't affect structure, they feel solid.
New ones similar on eBay look like £100, so £40 plus £10-20 post? Or i'm in Stone, Staffs if you could collect or meet. I can send photos if you u2u email address.
Ad
number-1
posted on 12/10/20 at 03:20 PM Reply With Quote
U2U sent
adampage
posted on 13/10/20 at 09:09 AM Reply With Quote
Sold, paid, posted, thanks!
[Edited on 14/10/20 by adampage]
