Author: Subject: 919 Honda Fireblade engine and parts to fit.
lsdweb
posted on 15/11/20 at 07:12 PM Reply With Quote
Hi all.
I have a large pile of 919 Fireblade parts for sale. These have come off my ex (Colin Chapman) RGB Fury or were part of the large spares package. The car is having a different engine package so all parts are for sale.
Everything is located in South Wales - we're not locked down but appreciate others are. I could pallet parts up for courier collection.
Prices are negotiable especially if you want to but a few things.
1.       Low mileage engine with standard sump, carbs, starter , ECU, coil packs, reg/rectifier, thermostat. A bundle of wiring of some sorts (the wiring on these is simple). £550
2.       Ex AB racing engine with synchro fault (believed to be 3rd gear). £200
3.       Ex AB racing engine with synchro fault (believed to be 4th gear). £200
Carbs and mounting rubbers x 2 @ £70
AB Racing alloy paddle shifter fitted to steering column top half, complete with cable bracket and gearbox / engine bracket. £100
AB racing billet sump. £100
Shortened stock sump £50
Tony Law air box complete with clamps etc. £100
Tony Law manifold and exhaust. £125
Spare manifold and exhaust. £75 https://i.imgur.com/duKu0Ezm.jpg
Engine mounts to fit engine into Fisher Fury (but will probably work in other BEC chassis.) £75
Spare ECU £15
Fireblade Dash x 2 @£50
Electric reverse mechanism (was on live axle car but could be adapted for IRS rear) £50
Sprocket adaptor looks unused £40
Sprocket adaptor used £25
Prop £100
Oil cooler adaptor and braided hoses. £25
Photos are all here - https://imgur.com/a/X6OmWeZ?nc=1&nc (sorry I can't attach them to posts anymore).
Wyn
[Edited on 16/11/20 by lsdweb]
Craigib76
posted on 15/11/20 at 07:32 PM Reply With Quote
Hi there interested in the paddle shift and brackets
Would you take a trade for my Aim mychron 3 plus for them?
Also do you have a floor mount pedal box that you would sell?
Regards Craig
[Edited on 15/11/20 by Craigib76]
lsdweb
posted on 16/11/20 at 08:34 AM Reply With Quote
Thanks Craig
No swaps sorry - I have a Race Technology dash .
Wyn
Regards Craig
Craigib76
posted on 16/11/20 at 01:16 PM Reply With Quote
Do you have any other images of the paddle shifter mainly how it mounts on to the steering column
Regards Craig
lsdweb
posted on 16/11/20 at 04:03 PM Reply With Quote
Regards Craig
lsdweb
posted on 16/11/20 at 04:04 PM Reply With Quote
It has brackets welded to the column Craig. I'm including the column (but not the inner so you'll need one - I think it's standard Sierra).
Craigib76
posted on 16/11/20 at 06:31 PM Reply With Quote
Yes mine is std Sierra as well so should not be a problem
Still interested in it
Will let you know 100% in a bit
Cheers Craig
jamiepearson69
posted on 19/11/20 at 12:58 PM Reply With Quote
Exhaust
Hi
What diameter is the silencer on the exhaust and do you know what Db if was on track?
James
lsdweb
posted on 19/11/20 at 05:24 PM Reply With Quote
Originally posted by jamiepearson69
Hi
James
Which exhaust? I have 2 for sale. And I can't tell you the sound level - too many variables to say.
Craigib76
posted on 21/11/20 at 06:12 PM Reply With Quote
Regards Craig
Hi what would the postage cost e like on this and are you open to an offer for the paddle shifter?
Craig
MadMaxx
posted on 22/11/20 at 07:44 AM Reply With Quote
What’s the difference between the AB racing engine and a standard one?
My re-building diary:
http://www.llcc.it/YetAnotherForum.NET/default.aspx?g=posts&t=13448
lsdweb
posted on 22/11/20 at 07:10 PM Reply With Quote
Supplied by Andy I believe so presumably a decent motor.
lsdweb
posted on 22/11/20 at 07:12 PM Reply With Quote
Airbox, 1 dash, prop, prop adaptor, paddle shift and oil cooler stuff all sold / promised.
RobBrodie
posted on 2/12/20 at 11:17 PM Reply With Quote
U2U sent
pmc_3
posted on 3/12/20 at 08:40 PM Reply With Quote
Any pictures of the electric reverse fitted Wyn? I'm using a live axle so I might be needing one.
View User's Profile View All Posts By User U2U Member This User Has MSN Messenger
lsdweb
posted on 3/12/20 at 08:59 PM Reply With Quote
Pete. It took me a while to work out but it fits at the gearbox end! I'm going to refit it when I get a chance to get some photos done.
pmc_3
posted on 3/12/20 at 11:26 PM Reply With Quote
Nice one, keep me posted. Cheers
