thetankwad
posted on 13/1/21 at 10:31 AM |
Smart Fortwo Steering Rack - Suitable?
As the title suggests. Had a search about and I cannot really see any mention of its use on a classic 7 build?
Physically it would look to be the boy for the job and avoid the need for any shortening shennanigans on another rack, but has anyone actually used
one in a build? Is there any drawbacks or hidden problems?
--Lets get down to Business!--
posted on 13/1/21 at 10:52 AM |
Talk to "Replicar328" on here. He's buidling a non 7 style car and has considered that very steering rack (and other Smart parts).
You appear to have the same line of thinking.
[Edited on 13/1/21 by nick205]
Replicar328
posted on 13/1/21 at 06:26 PM |
Thanks Nick205, you are right that I did consider using a Smart Car as a donor for the whole car because of the narrow track but was talked out of it
by experts on this site. I didn't actually look too carefully at the Smart Car steering rack but I believe I thought it looked a bit
lightweight, as did most of the mechanicals, so I went back to using an MX5 MkII as the donor and have had to have drive shafts shortened as well as
the propshaft.
Take a look at https://www.locostbuilders.co.uk/viewthread.php?tid=217744 . The Seicento rack I bought for a very reasonable price is ideal - 400mm
between the rack ends where they meet the tie rods which will allow me to have wishbones almost identical to the standard locost size, but with a
smaller track. Cheaper than shortening and in my view safer. Using the MX5 uprights with the rack in front of the wheel hibs I needed an LHD rack
flipped upside down.
Hope this helps
Adrian
russbost
posted on 13/1/21 at 07:52 PM |
To clarify, when you say "a classic 7 build" do you mean a typical 7?
If so, surely by using anything other than the donor rack that matches the rest of the parts you'll have a rack that doesn't match the
column, unless you use the Smart column (no idea if it's suitable or not), & the rack wont have the same thread as the TRE's, or if
you use the Smart TRE's they won't match the taper on the steering arms unless you're going to use all Smart bits? Or have I
completely misunderstood what you're doing?
Furore Formula Car - the only two seater modern Formula Car lookalike. I no longer run Furore Products or Furore Cars Ltd, but would still highly
recommend them for Acewell dashes, projector headlights, dominator headlights, indicators, mirrors etc, best prices in the UK! Take a look at
http://www.furoreproducts.co.uk/ or find more parts on Ebay, user names furoreltd & furoreproducts, discounts available for LCB users.
thetankwad
posted on 13/1/21 at 08:16 PM |
Thats great info thank you!
Whats the adaption like to the hubs? Custom work or are the threads on the inner or outer tie rods a match?
Similarly the input shaft?
Replicar328
posted on 14/1/21 at 10:58 AM |
With my Seicento steering rack I haven't checked yet whether the tie rod ends have the same thread or whether the adjustment is sufficient to
allow me to have the front track width I need. For now, I'm focusing on the chassis design to accommodate the rack width.
I need a track width which is 44mm less than the Seicento so I may be lucky. I must check the thread! If it doesn't work and I can't find
a ball joint tie rod end with the right thread which fits the upright, I've found that you can buy Steering Track Rod / Tie Rod Extenders on
ebay so I'd cut the rack tie rods shorter and re-thread them to get the overall length right.
As an alternative I recommend http://www.cpsdrivelink.co.uk/ who did an amazing job of shortening my drive shafts (with friction welding) so well that
you really can't see the join. They would probably be able to chop and friction weld two different tie rods together.
I'd welcome any suggestions of a better way!
