xxx
posted on 19/1/21 at 05:30 PM |
Steering Column Travel/Movement?
Evening all,
My steering column is fixed in place and I understand it has a collapsible section. However with a bit of force on the wheel it can be pushed along
the length of the column and pulled back. Clearly this isnt correct or safe, but what might I be missing to secure the column, any ideas?
Bad picture of connection to steering wheel boss:
  Steering Boss Connection
Movement can be seen in this portion (max gap shown)
  Steering Column Movement
Steering column for reference, I think its a Sierra?
  Steering Column in Scuttle
Its a bit like this, but not as cool or innovative:
Merc F1 DAS
big_wasa
posted on 19/1/21 at 06:18 PM |
The inner should have a big spring on the bottom. Behind the boss there should be a spacer. It would normally be black and have a lobe for cancelling
the indicator and a notch that locates in the boss.
With these to there will be no slop.
