Author: Subject: Garage clear out - exhaust, fuel pump and regulator, Duratec manifold flange
cosmicicecreamman
posted on 21/2/21 at 09:13 AM Reply With Quote
Exhaust silencer and clamps, 6” OD with 2.5” tube. Will split if someone wants the silencer or clamps separately - £20 for silencer and clamps.
Silencer - 1
Silencer - 1
Silencer - 2
Silencer - 2
Silencer - 3
Silencer - 3
Wilwood clutch slave cylinder, converts cable clutch to hydraulic, pull type cylinder - £30 posted.
Hyd - 1
Hyd - 1
Petrol king fuel pressure regulator - £20 posted
Press - 1
Press - 1
Press - 2
Press - 2
Duratec stainless exhaust manifold flange - £30 posted
Flange - 1
Flange - 1
Fuel pump, Facet - £30 posted
Fuel pump 1
Fuel pump 1
Fuel pump 2
Fuel pump 2
Ford Sierra rear wheel bearing housing - £12 posted
Bearing housings
Bearing housings
Ford Sierra rear brake calipers - £30 posted
Rear brake calipers
Rear brake calipers
More to come...
Thanks, Stephen
[Edited on 21/2/21 by cosmicicecreamman]
[Edited on 22/2/21 by cosmicicecreamman]
Hadders
posted on 22/2/21 at 11:17 AM Reply With Quote
I'll take the Wilwood brake bias adjuster knob please Icecreamman.
U2U your details and I'll PayPal you if that's okay?
Cheers.
Ben
CRAIGR
Contributor
Posts 2670
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 22/2/21 at 01:18 PM Reply With Quote
How loud/quiet is exhaust Steve ?
cosmicicecreamman
posted on 23/2/21 at 10:03 AM Reply With Quote
Updated list:
Hyd - 1
Hyd - 1
Press - 1
Press - 1
Press - 2
Press - 2
Flange - 1
Flange - 1
Fuel pump 1
Fuel pump 1
Fuel pump 2
Fuel pump 2
Bearing housings
Bearing housings
Rear brake calipers
Rear brake calipers
More to come...
Thanks, Stephen
