Author: Subject: Track Day Striker to loud
jester
Contributor
Posts 154
Registered 21/5/17
Member Is Offline
Photo Archive Go!
Building: brought Jester.building a Jester own a Striker
posted on 24/7/21 at 01:19 AM Reply With Quote
I have tried twice so far to pass the dB noise test at Castle Coombe
The first time I booked a slot it failed as it the was to noisey.
On getting the striker home I tuck the riveted Exhaust/Can apart it was like brand new
In there it was rammed with flat sheet packing.
The can had not long been brought for the car buy the last owner.
He said it was brought from RAW
The second time I Booked a slot a I fitted a dB killer in the pipe it still failed the dB test
The only mod's That the owner had done is to have the full bonnet hindge from the front
Picture 1 shows a cut out a hole in the bonnet
Picture 2 shows the cut out inside of the bonnet
Picture 3 shows a filter to a fiberglass box to the twin 40's
Picture 4 shows the fiberglass back plate on the twin 40's
The last picture shows the standard exhaust/Can
Would this make the striker to noise for a dB test.
The striker does have two stickers from old tracks day.
So all I can guess is that fiberglass box & hole in the boonet have made the striker to loud now
Striker Bonnet Top
Striker Bonnet Top
Striker Bonnet Underneath
Striker Carb Fiberglass box
Striker Carb Back Plate filter
Striker Stand alone F Filters
Striker stand alone B Filter
Striker Exhaust
Striker Exhaust
cliftyhanger
posted on 24/7/21 at 05:16 AM Reply With Quote
The airbox and filter will be quieter than the twin sock type filters, and release more power. Plus teh induction is teh opposite side and a fair way from the exhaust where tested.
99% you need a better exhaust.....
pigeondave
posted on 24/7/21 at 08:05 AM Reply With Quote
Hmm could be the problem. I was told 150-125g/litre for the packing, threads on here use the quilt stuff which expands due to the threads melting and releasing it.
I cant remember the name, but I do remember most say use less than they say in the calculator. Do a search on here for repacking exhausts and it'll show.
My exhaust repack is on JPSC forum "Stuffing the can".
Sound like a repack with possible slightly less material is your next option.
JMW
posted on 24/7/21 at 08:42 AM Reply With Quote
Acousta-fil?
jester
Contributor
Posts 154
Registered 21/5/17
Member Is Offline
Photo Archive Go!
posted on 24/7/21 at 10:38 AM Reply With Quote
That's a bit gutting as when I looked at the spare parts list on the Raw web site.
After I brought the striker for a price for a windscreen full or half size.
The can was listed at 250.00 Then to find out now that it's not fit for a track day
Glad I never brought the can myself.
jester
Contributor
Posts 154
Registered 21/5/17
Member Is Offline
Photo Archive Go!
posted on 24/7/21 at 10:40 AM Reply With Quote
Thanks for the spec's & other links
jester
Contributor
Posts 154
Registered 21/5/17
Member Is Offline
Photo Archive Go!
posted on 24/7/21 at 10:44 AM Reply With Quote
Originally posted by JMW
Acousta-fil?
Found a good post on the web about this stuff
https://www.lotus7.club/forum/techtalk/acousta-fil-exhaust-packing?page=1
Looks to be the stuff
adithorp
posted on 24/7/21 at 12:22 PM Reply With Quote
Sounds like your exhaust might be over packed, as others have said.
I'd repack with acoustafil. Use the online calculator but then put in 25-30% less than it suggests. That's what's been found works best in practice. It'll look pretty empty but once the quilting tread melts it'll expand to fill the space. You won't need the stainless wire wool as pigeondave used if using acoustic.
http://jpsc.org.uk/forum/
jester
Contributor
Posts 154
Registered 21/5/17
Member Is Offline
Photo Archive Go!
posted on 25/7/21 at 12:19 PM Reply With Quote
Here is some pictures of the currant packing that is in the Exhaust/Can
That was brought by the last owner from Raw
Sanzomat
posted on 25/7/21 at 01:30 PM Reply With Quote
Just wondering what figure they gave you when you failed? If it was a long way over then it'll take a lot to bring it down (obviously) but if not a lot over then tweaks might get you there. Remember it is a logarithmic scale so every ten dB is double the sound so if you were testing at, say, 108, then I doubt that repacking an existing can will get you below 100 but if you got, say, 103, when you failed you might get there.
If you are after a big reduction it'll have to be a longer and wider can.
Also worth trying (if you don't already have one) a 90 degree bend on the outlet pointing slightly downwards. I've heard just that alone saving a whole dB and hardly any back pressure.
I've been to Combe a lot as it is only 11 miles from home. I've always found the guys to be friendly and helpful and they can often give a bit of advice. For my BEC they accepted my saying I was trying a new map so was going to keep it below 10,500 so let me test at 7500rpm instead of 8k
pigeondave
posted on 25/7/21 at 03:52 PM Reply With Quote
Ah well you got it open now, might as well carefully pull it out and weigh it and put in slightly less if its over.
Or go straight for the Acustafil (sp) option ?
Then again is it a case of the can is too small?
I'm limited of what I can fit in the side pod of the Fury. I've seen many a Stylus owner cut the side pod and have a bigger can exposed.
Horses for courses I think, if you want to do a lot of track days, massive can and you wont have the bother. Occasional track days, try repacking what you have.
[Edited on 25/7/21 by pigeondave]
jester
Contributor
Posts 154
Registered 21/5/17
Member Is Offline
Photo Archive Go!
posted on 25/7/21 at 04:51 PM Reply With Quote
dB reading was 108 the first time.The guy testing said this is a bike engine right I said no it's a 1700-Xflow
The second time I went it had a dB of 103 with a muffler in the exhaust end.
The exhaust has a 90 degree bend on the outlet all ready. As in the first lot of pictures.
I am booking the striker in for it's second mot shortly so I will ask them if they have a dB tester on site.
as the speedo has started running out now after 30ish miles@hr now so maybe the rev's are out as well now
So I may have been over reving the striker for the dB testing a Castle Combe
Its running motorbike digi dash for everything the fuel gauge has allways been a bit hit and miss
So fingers crossed on this. if not then repacking might help as other have said
jester
Contributor
Posts 154
Registered 21/5/17
Member Is Offline
Photo Archive Go!
posted on 25/7/21 at 05:19 PM Reply With Quote
That's good to no.
That I dont have to buy the wirewool as well as it starts to get a bit of a dear job other wise
bi22le
posted on 25/7/21 at 10:32 PM Reply With Quote
What a pain.
If you are getting 108 static they is quite alot. I doubt it's intake side as you are not trudging on a drive by and as mentioned they box should get the noise down.
I have a RAW exhaust and get about 98 static with acoustafil. Certainly worth repacking.
Also check for and holes in your exhaust.
Focal tip, unsure how you are getting your dB tests done but if you ask a day of so before you will be allowed to rock up at a track day and just get it tested.
The marshals, if good ones, are often very experienced and helpful.
I hope you get it sorted and get to go out and play
Please read my ring story:
Rich J
posted on 26/7/21 at 07:57 AM Reply With Quote
Made the mistake of using the Acoustafil calculator so have a 2 foot by 4 foot piece left over if it's of use to you
ttalps2000
posted on 26/7/21 at 10:00 AM Reply With Quote
i have the same silencer. At IVA it was 99 and flickering to 100. After i repacked it with Acoustafil and was tested a few weeks ago at castle coombe and is 96db, massive improvement. Just have to drive it hard and get it bloody hot to expand etc, i did about 150 miles non stop to get mine to where it needed to be!
perksy
posted on 26/7/21 at 09:09 PM Reply With Quote
Repacked my SBD silencer with Acostafil and was very impressed with it
jester
Contributor
Posts 154
Registered 21/5/17
Member Is Offline
Photo Archive Go!
posted on 26/7/21 at 10:50 PM Reply With Quote
Originally posted by bi22le
What a pain.
That it is.
They only have a few dates left at Castle Combe that can be booked this year as well
I missed out on two dates all ready trying to get this sorted
The testing has been done at Castle Combe on both times.
Have to book the time's as well
98dB sounds good
jester
Contributor
Posts 154
Registered 21/5/17
Member Is Offline
Photo Archive Go!
posted on 26/7/21 at 10:54 PM Reply With Quote
OMG
Other post have said get the size then take off X-mount
Is it that far out
jester
Contributor
Posts 154
Registered 21/5/17
Member Is Offline
Photo Archive Go!
posted on 26/7/21 at 10:56 PM Reply With Quote
That sounds good.
150 Miles Tyres should last
jester
Contributor
Posts 154
Registered 21/5/17
Member Is Offline
Photo Archive Go!
posted on 26/7/21 at 11:02 PM Reply With Quote
Sounds like this is the stuff to get
ttalps2000
posted on 27/7/21 at 07:31 AM Reply With Quote
Dont tightly pack it though as it expands! It stinks for a while too, but the key is to get it hot. Wasnt until i went out on the motorway where it got some decent heat into it that it began to quieten down
