Author: Subject: Any spray painters on here?
number-1
posted on 8/10/22 at 03:41 PM Reply With Quote
I have a question about a particular paint code for a Honda motorcycle. The paint code is PB215C Candy Tahitian blue (motorcycle), 3 stage paint.
Now i know the 3 stage is glittery silver base, a few coats of the blue until the right colour is reached and then a clear coat. The question is.....what primer colour should be used?
I'm trying to repair a small area on the bike and will probably end up paying someone to do it properly, but thought id give it a try myself first as it only needs to look semi decent
N1
russbost
posted on 10/10/22 at 08:18 AM Reply With Quote
The primer won't make a significant difference unless very dark, Iwould think any white, grey or beige would be fine, if what's going over it isn't giving coverage then you'd need more coats anyway.
No experience with the triple coat system you describe, but years of painting clear over base
