Author: Subject: Is there a source for flywheel technical drawings or measurements?
J666AYP
posted on 8/3/23 at 04:56 PM Reply With Quote
Hi all,
I'm trying to find out the measurements/dimensions on two different flywheels so I can do a solid mass conversion on my project. There is a off the shelf item that is a direct fit but it will run me between £1600-2100 depending on spec.
There is another vehicle that shares the same block/crank as my car that has a solid mass kit available for less than £600 shipped. As you can emagine this would be far preferable to the expensive one.
The problem is buying a standard DMf and the possible SMF donor just to check side by side is going to be very costly for a maybe. So does anyone know of a resource that will have dimensions, tooth number etc ect maybe a parts book or something? The part numbers are not exactly much help either due to the different vehicle platforms.
I have approached mercedes twice now and both times I've been met with blank faces by sales desk people who likely don't know what a flywheel is so thats a dead end.
Any thoughts appreciated
Jay
[Edited on 8/3/23 by J666AYP]
gremlin1234
posted on 8/3/23 at 06:39 PM Reply With Quote
does this help... https://www.hammerkupplungen.com/uploads/TECHNICAL%20CATALOGUE1561536520.pdf
Mr Whippy
posted on 9/3/23 at 01:12 PM Reply With Quote
Why are you looking at a solid flywheel, at that cost to replace the dual mass one is it really worth the money?
I've had a dual mass go before but some say replacing it with a solid one will wear out the gearbox quicker by not damping loads or vibration from the engine to the gearbox.
J666AYP
posted on 10/3/23 at 01:27 AM Reply With Quote
Thanks for that, will give me something to cross reference parts numbers and hopefully find a solution 👍
J666AYP
posted on 10/3/23 at 01:33 AM Reply With Quote
The problem is the DMF that come with the donor was shot already, so either way I have to replace it. My options are spend 500-800 (brand dependant) on a standard DMF or shell out alot more on a SMF kit. Hence the reason for trying to cross reference parts to see if I could make myown SMF "kit" for the price of a standard DMF
Also there is the utterly disgusting fact that the standard DMF is a whopping 19.5kgs and really numbs the little engine that just wants to rev.
J
