Author: Subject: IVA central register
ollie2910
posted on 19/7/23 at 06:25 PM Reply With Quote
Does anyone know if there is a central register for vehicle's which have passed an IVA? I have a vehicle which and various IVA bits of paper work including a couple of minor fails but no certificate that clearly says pass.
The car is registered (does this show that it has passed an IVA)
many thanks. :-)
Ollie
gremlin1234
posted on 19/7/23 at 06:36 PM Reply With Quote
when registering the car dvla keep the [iva] certificate
[Edited on 19-7-2023 by gremlin1234]
ollie2910
posted on 20/7/23 at 06:23 AM Reply With Quote
Thanks Gremlin1234, that would make sense, a certificate in exchange for a reg document.
Ollie
Rallychris
posted on 20/7/23 at 09:37 AM Reply With Quote
But like everything to do with the DVLA's database they probably are incapable of providing any report of IVA records if you were to ask them.
I have a situation that many other kit builders have faced when using an engine from an unknown donor, even if the engine type clearly links to a specific age range for the vehicle production; to be IVA tested to the relevant age emissions spec and for any age related registration application you need to prove the age of the engine, even though the data must exist already on the DVLA database as the engine number is listed on every car's V5.
posted on 20/7/23 at 01:24 PM Reply With Quote
Most car manufacturers will wite back confirming the engine age if you contact them with the engine number though won't they?
I know Ford do (because I wrote to them to verify the age of my Pinto engine).
Rallychris
posted on 20/7/23 at 02:52 PM Reply With Quote
Unfortunately not Mazda - they also can't interrogate their own database and can only work off a vehicle VIN number in order to validate the age of an engine.
