KJK
| posted on 4/2/05 at 08:01 PM |
ex up or not
if i use an r1 do you have to use exup?
| posted on 4/2/05 at 08:13 PM |
the exup valve is there to regulate back pressure. this is to increase performance and to reduce emissions. i think the engine will run without it but
there may be some complications on the wiring side.
as an aside, R1 users rarely mention the exup valve, so maybe this is a sign that it isnt used.
ChrisGamlin
| posted on 4/2/05 at 08:14 PM |
Nope. Evidently there's a mod you can do to stop the error code appearing on the dash which Im sure Paul (Rogers) will know, but it can be
junked.
| posted on 4/2/05 at 08:19 PM |
do people junk it because back pressure helps low end torque and they are after top end power?
colibriman
you don't have to use it, you can just plug it into the loom but not attach the cables, if you dont plug it in to the loom though you get a
fault code on the R1 clocks (if your using them).
I think there's a way to fool the cdi into thinking there's one fitted - I think you fit a resistor but not sure.
HTH
Colin
Doh...beat me to it!
[Edited on 4/2/05 by colibriman]
need a bike engine? - www.colibriman.com
SVA ready Mk Indyblade possibly for sale.....if the offers good...!
Bob C
| posted on 4/2/05 at 11:19 PM |
can't do it with a resistor. There was a site "bikeenginetransplant" or something like that with a complex "exup
pretender" circuit in. I've got a much simpler idea using a cheap optotransistor, a transistor and a capacitor which I'll try when
engine start time comes, when I make it work I'll publish but don't hold your breath...
If someone wants to try & debug it for me get in touch!!!
Bob C
colibriman
posted on 4/2/05 at 11:24 PM |
by 'debug do you mean try it to see if anything goes up in smoke?
mangogrooveworkshop
| posted on 4/2/05 at 11:37 PM |
http://biketransplant.tripod.com
[Edited on 4-2-05 by mangogrooveworkshop]
http://www.jbracing.co.uk/Details.cfm?ProdID=39
Its more expensive than a exup valve!
athoirs
| posted on 5/2/05 at 10:56 AM |
I made one up from the biketransplant site and it worked no problem at all, It must of cost me about 20 quid tops, I wondered if it was worth making
these for others- would there be a demand?
Bob C
| posted on 5/2/05 at 03:21 PM |
pretty much! Excellent - so I have a volunteer then!!
Actually someone with a working BEC would make the best test vehicle.
It shouldn't be able to cause any smoke really.......
t'would be a tiny little thing that would be built into the loom plug.
Bob
colibriman
| posted on 5/2/05 at 03:56 PM |
hmmmm......
before after
due to the flash, bang, smokin effect
progers
| posted on 6/2/05 at 10:05 AM |
EXUP NOT needed
Hi All,
You can definitely get rid of the EXUP and still keep the original clocks. If you short the red/white wires the only time you will get the fault
indication (tacho bouncing between 0 and 6k revs I think) is when the ignition is on but the engine if off.
All other conditions (engine running or in any gear) there is no interference with the tacho function.
See http://www.samannasystems.com/chart.html
Why get rid of the EXUP? you can get better torque and power without it - don't forget most BECs have custom intakes and exhausts so you can
take advantage of this to improve on the basic 4-1 exhaust and airbox that Yamaha used. 160hp is easy to get with better intake, exhaust and a
rejet.
Paul
colibriman
| posted on 6/2/05 at 10:48 AM |
Cool...thats handy to know....cheers Paul
Stu16v
| posted on 6/2/05 at 05:39 PM |
And even though it is still finding a fault, it definately isn't putting the ECU into a get-you-home mode?
heyzee
| posted on 6/2/05 at 05:46 PM |
ex up
does this mean that you dont need the servo too???????????????or is the servo still to be used????????
Coose
| posted on 6/2/05 at 09:52 PM |
My servo cost me £20, so I should have no fault code problems!
One tip though - don't bothr using the valve as they were developed to get the bikes through the homologation drive-by noise tests! They have no
effect on bottom end performance whatsoever! I would actually suspect they have an adverse effect in that they possibly do not allow all spent gases
out of the motor at low engine speeds.....
Spin 'er off Well...
colibriman
| posted on 6/2/05 at 09:53 PM |
How's progress Ian?
progers
| posted on 7/2/05 at 11:18 AM |
EXUP myths
Just to confirm that loss of EXUP does not affect the performance of the engine by putting the ECU into a different mode.
My ex Indy R1 (no EXUP) was measured at 138 rear wheel HP by TTS in Northampton. This equates to 160-165bhp at the crank. A healthy increase over the
standard 150bhp Yamaha quote :-)
You can still connect the servo if you wish, it just adds a few Kgs of unnecessary weight.
By the way, people should also junk the AIS system as all this does is to inject air into the exhaust to help with emissions. It screws up any add-on
SVA CAT exhaust kit too when it comes to measuring emissions. Junk it and just block up the holes that feed into the exhaust ports. Another couple of
Kgs saved!
Paul
Coose
| posted on 7/2/05 at 02:02 PM |
progers - I'm fitting the servo only as I'm using the R1 clocks and didn't want the fault code to show.... But that's
certainly good news about not giving a fault ignition map! I've heard mixed reports about this, but suspected that there wouldn't be such
a thing as, to be honest, the stock ignition curve is pretty conservative anyway!
Colin - it's coming on well ta! I'm in the middle of sorting out the loom, then got the gearchange linkage to sort (waiting for some
paddles to arrive from Mr Rarity) and then we'll almost be ready to roll! Oh yeah, I'm still in a dilemma of what to do about the diff -
do I leave the 3.89 in for now (14" wheels) and see just how undergeared it is, do I bite the bullet and get a 3.54 Quaife ATB that I've
been offered, do I pick up a 3.54 open diff and wish I'd bought the ATB in a few months time, or do I buy a cheap set is 15" rear
wheels?
Would you believe I missed a 3.54 from Marc by two days? D'OH!!!!!
short track 123
| posted on 26/4/05 at 07:59 PM |
Why would you wona get rid of the EXUp????
ChrisGamlin
| posted on 26/4/05 at 08:19 PM |
Cos its a great hunk of metal that would sit out somewhere along side the passenger for all to see if installed on a Locost style BEC?
Its only there to improve mid range slightly anyway, top end isnt affected and with a decent exhaust design you dont lose any mid range either.
short track 123
| posted on 27/4/05 at 06:01 PM |
EXUP
I can see what you mean about the look of it.
But as for power.The % of midrange throttle is higher on the road ( and some race tracks ) than the % of full throttle and should than be faster ?
Do you not agree?
Jason
ChrisGamlin
| posted on 27/4/05 at 06:13 PM |
I dont know of any kit car that's actually used it so I guess its a bit hard to compare, but a lot of the bike tuning companies bin it when they
tune the R1s so it can't be that beneficial IMHO.
short track 123
| posted on 27/4/05 at 07:04 PM |
EXUP
I think tunners like to show big numbers on the dyno to people who are spending becouse the 1st thing people ask is whats the BHP.
Jason
OX
| posted on 27/4/05 at 08:12 PM |
i read a website that said if you fit a 4-2-1 exhaust system it brings back the lower end power that you lose by not using the exup valve.
but with the exup motor i had mixed feelings,heard so many stories about it making a difference or it not making a difference that i ended up using
the motor becouse i wasnt bothered about the weight
