Author: Subject: Weird Pats Issue
turnipfarmer
posted on 21/4/24 at 03:28 PM Reply With Quote
Weird Pats Issue
Hi, guys...
After working fine up to a few days ago, my Pats LED has suddenly thrown a wobbly.
When I turn on the battery isolator, the Pats LED immediately goes solid red and stays like that. Turn on the ignition and it goes off - the starter works OK, and the engine runs. Switch off the ignition again, and it goes back to solid red, Try as I might, I can't see anything wrong with the wiring. Done all the usual things like disconnecting the battery, looking for fault codes etc, but nothing helps.
Anybody got any ideas as to what's causing it?
