New Topic New Reply
Author: Subject: Total length required
Avoneer
posted on 6/3/05 at 10:43 PM Reply With Quote
This has probably been asked a million times.
Does anyone know roughly how much length is required of 25x25, 19x19 and 19 round?
Pat...
white130d
posted on 6/3/05 at 10:50 PM Reply With Quote
Check the cut list
Mcsorley has a full cut list on his site...
It is an excel file.
cut list
David.
"There's only 2 things that money can't buy, and that's true love and home grown tomatos" Guy Clark
Spottty
Well, I added up a book chassis and its about 100ft of 1x1 20ft of 3/4 x 3/4 and 18ft 3/4 round.
I was told you should add about 10% to the length and with careful cuts you should have enough.
Its not too bad, I phoned the steel shop and worked out to about $300 CAN. or about 120 Pounds/Quid what ever you guys call it
Best thing to do for a build....
Ditch the wife!
chrism
posted on 6/3/05 at 10:56 PM Reply With Quote
Wow, £120 seems a lot.
My steel cost around £50 + Vat = around £59.
And that was including a sheet of 4ft x 2ft 3mm Plate.
A little hard work never killed anyone, but why take the risk!
clbarclay
posted on 6/3/05 at 10:57 PM Reply With Quote
Don't forget when ordering steel items like the scutle which uses a C of 25x25 RHS as a base.
Also front wheel mudguard mounts.
I'm sure theres more but these 2 are the ones I can think of at the moment.
[Edited on 6/3/05 by clbarclay]
clbarclay
posted on 6/3/05 at 10:58 PM Reply With Quote
All depends when you get your steel. steel prices are quite variable from one moment to the next.
James
posted on 7/3/05 at 10:07 AM Reply With Quote
Pat,
Bear in mind you'll need some more if you're doing the Cymtriks' mods to your chassis.
James
Danozeman
posted on 7/3/05 at 02:42 PM Reply With Quote
the metal i got when i was gonna make my chassis came to about 90 quid and i had loads spare... I got it in 4 metre lengths.
Dan
clbarclay
posted on 7/3/05 at 07:31 PM Reply With Quote
I can not remember the exact cost of my steel but it was about £160-180 but that included 4x8 foot sheats of 3mm and 16swg. It may also include the CDS for suspension (2 x 6m lenghts).
New Topic New Reply
