Author: Subject: Clutch Pedal Height
DrEagle
posted on 9/4/05 at 08:42 PM Reply With Quote
Clutch Pedal Height
I have just fitted a modified sierra pedal box, after connecting the clutch cable, the clutch pedal sits very high.
There is an auto adjuster thing but, can i do something to make the pedal sit at a sencible height or do i need a longer cable????
Pedal boxes are hardest part!
[Edited on 9/4/05 by DrEagle]
Never be afraid to try something new!
Remember that a lone amateur built the Ark with no budget,
where as a large group of professionals spent millions building the Titanic!
RogerM
posted on 9/4/05 at 09:00 PM Reply With Quote
Surely there is some adjustment in the cable-stops either at pedal or bellhousing end?
If there is wind them in to loosen the cable tension, that should work.
If not it will be a matter of trimming some material of one of the stops.
With Sierra pedal boxes it is important to make sure that it is the zero adjustment position when you first install the cable and that the pedal upstop is arranged to give a position just above what is desired. The auto adjuster should do the rest for you.
Chris_R
posted on 9/4/05 at 10:05 PM Reply With Quote
Don't know the answer, but these may help someone to find it.
Modified pedal box
Modified pedal box
Modified pedal box
Modified pedal box
Modified pedal box
Modified pedal box
A bit of slapstick never hurt anyone.
http://www.chris.renney.dsl.pipex.com/
Mark Allanson
posted on 9/4/05 at 10:22 PM Reply With Quote
Just work the pedal a few times, the ratchet adjuster should bring it down to size
indykid
posted on 10/4/05 at 06:29 PM Reply With Quote
even in the sierra it sits too high imo.
as far as i can see, to make the pedal sit lower, you need to extend the piece of steel that the pawl of the ratchet sits on to disengage the ratchet and tighten the cable.
there's no other way to induce slack as the ratchet will always take it up.
if not, cut and re weld the pedal to the height you want it
hth
tom
RoadkillUK
posted on 10/4/05 at 07:50 PM Reply With Quote
Why not make a stop so the pedal can only go so far back?
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
DrEagle
posted on 10/4/05 at 07:55 PM Reply With Quote
cheers chaps.
I will see how it is to drive.
I think it keeps it out of the way above the break and gives me somewhere to rest my left foot.
Chris_R
posted on 10/4/05 at 10:24 PM Reply With Quote
When I did mine I cut the 'this bit' off, shortened it (width ways) and re-welded it. You could move it up a little.
