dads7
posted on 12/4/05 at 06:20 PM |
paddle change
Is anyone out there using a paddle change? If so have you used a kit and where can I get one from? How reliable is it? I know that I'm always
asking questions but I've only just started!!!!! ![](/images//smilies/smile.gif)
ChrisGamlin
posted on 12/4/05 at 09:27 PM |
Stuart Taylor do one, as do Kit Car Workshop I think (and probably MK etc too), probably worth giving them a call.
OX
posted on 12/4/05 at 11:11 PM |
a few of us have made our own ,heres how i did mine paddle change but if you want something less
agricultural then buy one
phil_far
posted on 13/4/05 at 12:26 PM |
I bought mine paddle shift from a guy named Henry Carr. Its a simple push-pull system and uses a lever (similar to Dax's Cow-horn design) behind
the sterring wheel some small spherical bearings and a 'flexible solid metal cable' that is similar to those found on a $100,000 Sunseeker
power boats to control the throttle etc..
It is very simple and the total kit with all the stuff weighs at just 1.2kg. I do not know if he still makes them but to have an idea in how it looks
like visit this web site www.best-guess.co.uk and go through his 2004 build diary as this guy used one. My car is not on the road yet but general
impression is very good. I can e-mail you his address if you want to. Price was very reasonabel as well!
Philip
Coose
posted on 13/4/05 at 12:39 PM |
Have a look here at mine (at the bottom of page 1)....
http://www.ne7ers.co.uk/modules.php?set_albumName=albun01&op=modload&name=Gallery&file=index&include=view_album.php
I have a luvly CNC machined ali paddle to go on once I get around to it - the steel one was knocked up to get it going!
Spin 'er off Well...
andy d (rizla)
posted on 13/4/05 at 04:00 PM |
you could always get one of these,then make paddles to operate the buttons
http://www.kliktronic.co.uk/
thats my intention
dads7
posted on 14/4/05 at 08:52 AM |
cheers lads
I think I'm going to try rizla's electro-mechnical idea, can it be used with a clutchless electronic up/down shift kit
locoboy
posted on 14/4/05 at 09:28 AM |
[Quote]Originally posted by dads7
cheers lads
Why?
Its all just extra weight and electrical headaches.
a simple manual paddle shift will be more reliable and you will be able to 'feel' for those potentially tricky 'selecting neutral or
1st' moments!.
Locoboy
Aloupol
posted on 14/4/05 at 09:44 AM |
One more step guys..
What about the combined clutch action at downshift to allow left foot braking?
For me there are only two options:
- Vintage: classic gear stick and 3 pedals.
- Modern : paddle or electric shift with 2 pedals.
I don't see any interest in a paddle shift if I still have to use this old fashioned clutch pedal... ![](/images//smilies/bigsmile.gif)
dads7
posted on 14/4/05 at 11:14 AM |
that's what I am trying to achieve. I don't think the kit that Rizla is suggesting would be too complicated looks like a solenoid or
linear actuator to me this has to lighter than a mechanism (less moving parts)????
Wouldn't you still need a clutch pedal to start and stop or am I being thick again ![](/images//smilies/sad.gif) ![](/images//smilies/tongue.gif)
locoboy
posted on 14/4/05 at 11:39 AM |
I think you will find that cutchless upshifts are ok but downshifts are a no no.
You will still need a clutch pedal for stopping and starting unless you want to trash your gearbox before you manage to get it off the driveway.
Locoboy
MarkClow
posted on 14/4/05 at 01:27 PM |
Do you have Henry Carr's email or web address? I am very interested in this....
Thanks!
Mark
tks
posted on 14/4/05 at 03:33 PM |
Well
in fact i'm making
a 2 foot system
my clutch a hydro one is gonna be actuated by electrics..
the clutch pedal is going to stay where it is just electrical version..
and is for going to 1st gear..
after that you don't need it anymore
(in fact its there for feeling)
When it works i will post..how i did it
TKS
andy d (rizla)
posted on 14/4/05 at 04:18 PM |
the klicktronic can be used up and down the box without using the clutch it has the gizmos to do that as a option
andy d (rizla)
posted on 14/4/05 at 04:30 PM |
quote from the web site faq section
Q: Can I use the Kliktronic with an ignition interrupt system?
A: Yes, the unit is compatible with all popular interrupt systems, in particular we recommend the Techtronics system which can be triggered directly
from our buttons using an additional module.
dads7
posted on 14/4/05 at 06:10 PM |
cheers Andy have you got the system running yet? I have read about the techtronics system and down changes sounds spot on to me.
Had a laugh at the links on your site too posted most of them round work in a feeble attempt to gain friends and influence people![](/images//smilies/bigsmile.gif)
subk2002
posted on 15/4/05 at 04:29 PM |
How much is the kliktronic set up ?
andy d (rizla)
posted on 15/4/05 at 04:31 PM |
under £500
jambojeef
posted on 15/4/05 at 08:43 PM |
made this today!
Gonna run it and maybe add some electronic stuff later - always got a back up if something fails miles from home!
Might cut it in half and and a removable top section for when the lectrics work!
[Edited on 15/4/05 by jambojeef]
![](/galpreviews/a203044-gearstick.JPG) ![Rescued attachment gearstick.JPG](/gallery/a203044-gearstick.JPG) Rescued attachment gearstick.JPG
ChrisGamlin
posted on 15/4/05 at 09:51 PM |
That'll keep the wife happy
jambojeef
posted on 15/4/05 at 10:13 PM |
he he he!
Cant say that I made it with her enjoyment in mind more mine! Wonder what that says about my subconscious!
A little test for you Chris....!
http://web.tickle.com/tests/inkblot/authorize/register.jsp?url=/tests/inkblot/index.jsp
![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
