Author: Subject: Zetec Ignition Map
perksy
posted on 15/4/05 at 09:31 PM Reply With Quote
Zetec Ignition Map
Does anybody have a 2 litre Zetec ignition map (on carb's ) they could send me ?
Have Built Megajolt, and would like to look at some Ignition maps to give me an idea.
Omex, MBE, Emerald etc would be very useful.
Thanks.
mark.perksy@btinternet.com
Stu16v
posted on 15/4/05 at 10:36 PM Reply With Quote
Hello Mr P, and welcome.
As you can probably guess, can't help with your request though...
MkIndy7
posted on 16/4/05 at 12:03 AM Reply With Quote
Just found these if there any good to you,
http://www.cate1.co.uk/megajolt/mapping.php
Good Luck and Happy Mapping
Ian
perksy
posted on 16/4/05 at 07:30 PM Reply With Quote
Hi Stu, Thought i'd join you lads on Here and See what You get up to
MkIndy, Thanks for that Info', But already have it saved, Anybody else ?
FatChapChipChop
posted on 20/4/05 at 08:06 AM Reply With Quote
Attached is a base map from Emerald for a Zetec .. Injection fuelling but the ignition map is pretty sound .. Good starting point, got a few friends cars going with this ..
It's a text file, you can open with Notepad and the like.
Cheers !!
Neil Wain
[Edited on 20/4/05 by FatChapChipChop]
Drive fast, don't look back!
Surrey Dave
posted on 20/4/05 at 12:49 PM Reply With Quote
Map looks interesting ,I can see 16 load sites vertically but why are there many more horizontally?
can you explain the map a little?
I would need to convert it over to 10 load sites for Megajolt.............
givemethebighammer
posted on 20/4/05 at 02:26 PM Reply With Quote
Here is the map copied from my Raceline GEMS miniDLS ecu.
perksy
posted on 20/4/05 at 06:24 PM Reply With Quote
Thanks Lads...
Givemethebighammer that Map is going to very useful.
Thanks Again.
givemethebighammer
posted on 20/4/05 at 10:29 PM Reply With Quote
No problem, the original raceline file was called "cat16w". Apparently they use the same map for all their zetec engines up to 190BHP. My GEMS setup uses a weber throttle pot and the standard zetec coil pack and crank position sensor.
With the above and the twin 45's the car runs well. Still due for a rolling road visit to make the final tweaks to the carb jetting soon.
stevebubs
posted on 20/4/05 at 10:48 PM Reply With Quote
Load sites vs RPM
Surrey Dave
posted on 21/4/05 at 06:29 PM Reply With Quote
Yes the Gems one makes sense but the Emerald map is not so clear , any explanations?
paulf
posted on 21/4/05 at 08:00 PM Reply With Quote
Have a look on www.cate1.co.uk.This is a tiger cat site but has a good section about Megajolt and a number of maps on there.
Paul
