New Topic New Reply
Author: Subject: single donor (Sierra) plans?
PerspexIt
posted on 20/3/02 at 12:33 PM Reply With Quote
Hi All!
somebody know if i can buy plans for a single donor (Sierra) locost?
Thanks,
Danny
posted on 20/3/02 at 12:42 PM Reply With Quote
MK engineering do a car called The Indy not a locust but similar sort of thing,
http://www.mkengineering.co.uk/
PerspexIt
posted on 20/3/02 at 03:11 PM Reply With Quote
I was searching for a drawing, like in the "book" but for Sierra, Escort parts are close to impossible to find in my contry.
Thanks,
James
posted on 21/3/02 at 09:39 AM Reply With Quote
David,
Try the files section on the Yahoo Locost group:
http://groups.yahoo.com/group/locost/
(you'll need to sign in and setup a yahoo id to get into the files section from there).
I believe there may be some .dxf files with IRS (Sierra rear end) plans. You'll need a CAD program to read them- I think Turbocad can be downloaded for free at: http://www.turbocad.com
Otherwise, there are loads of IRS photos around, try the photos section here on this site.
Also, the MK Indy on http://www.mkengineering.co.uk/
is fantastic if you want to buy an IRS chassis but the photos of the chassis on the MK site are pretty good too...
Other than that, find a kind mate who's already got one and measure up and copy his- although I'm sure no one around here would reverse engineer someone else's work....
James
Dutchman
posted on 14/2/06 at 01:23 PM Reply With Quote
So PerspexIt did U find anything .... or someone else... I have the same problem with finding escort in Serbia that is imposible there is none in the adds that is older than 84.
now thinking about LADA
Tarzan English with foreign accent!
ProjectX
posted on 14/2/06 at 11:18 PM Reply With Quote
Hi I'm building a Locost with Sierra rear end.
Look up RORTY's for the sierra IRS plans. Will fit book based Locost
J
Dutchman
posted on 15/2/06 at 10:33 AM Reply With Quote
So that means that if I do a McSorley 7+4 form http://www.mcsorley.net/locost/drawings/McSorley7+4.pdf
and the back of chassis from Rorty's http://gtslocost.locostsites.co.uk/documents/pdf_files/RortyLocostIRSAssembly.pdf
of course the uprights and forks ... I can Use only Sierra parts .
Schrodinger
posted on 15/2/06 at 04:14 PM Reply With Quote
There is the Tiger Avon which is supposed to be buildable from the book (Build a Tiger Avon)and that is Sierra based.
Keith
Suffolk
ProjectX
posted on 15/2/06 at 07:04 PM Reply With Quote
Yep thats what I'm doing. The IRS plans arn't for the +4 but easy enough to change the dimensions.
Front hubs from Sierra will need reaming to fit.
Hope this helps?
J
New Topic New Reply
