d1camero
posted on 9/5/05 at 03:51 AM |
Wheel/Tire/Hub selection for scratchbuilt
I am building a lightweight street legal sports car (including frame and body). It will be a 1600 lb 2 seater RWD speedster (mid engine) with full
independant suspension and discs all around.
To start I want to select tires, wheels and hubs. I am looking for suggestions for common tires, wheels and hubs that would be lightweight, good
performance, readily available
and "relatively" inexpensive.
Looking at the SCCA Spec Ford racer (which is 1600lbs) it uses:
Rims:
13 inches x 5.5 inches
13 inches x 7 inches
Tires:
185/60-13 for the front
205/60-13 for the rear
The hubs have 9" rotors.
Since the car will look similar to the Opel Eco Speedster, their wheels are:
175/55 R 17
Any suggestions are greatly appreciated. - thanks
d1
Alan B
posted on 9/5/05 at 12:06 PM |
Hi and welcome,
I suggest you repost this in the mid-engine section, and check out a few of us middy builders web sites (mine included, click www below)
Alan
posted on 9/5/05 at 08:30 PM |
the 13x5.5 and 13x7 is EXACTLY what i am using, and i think the tyres are also the same.
not sure what wheels are like in US (is that where you are? not sure...) but im using minilights (replicas actually, i think).
