Author: Subject: Avon book
Spottty
posted on 14/5/05 at 07:06 AM Reply With Quote
Avon book
I was wondering if anyone has built the chassis from the Tiger book?
I was going to build the regular book chassis but I have an IRS so I figure I will just use the Tiger book.
Any problems I should look out for? Did anyone change it (suchs as widen or lengthen)? Or should I build a McSorley book chassis front and try and adapt an IRS too it?
Any tips would be great.
Best thing to do for a build....
Ditch the wife!
Mix
posted on 14/5/05 at 07:30 AM Reply With Quote
I started to do just that
Then I discovered that the rear wishbones would converge if I followed the Avon dimensions. I've now re-jigged the IRS to give me, (theoretically) better geometry and a better transition between the book chassis and the IRS.
On a slightly different note, depending on which engine you intend to use I would consider making the chassis a bit taller.
Finally use the book and McSorley plans in conjunction with each other.
Mick
[Edited on 14/5/05 by Mix]
Northy
posted on 14/5/05 at 08:13 AM Reply With Quote
Mix do you have any drawings of the alterations you made?
Graham
Spottty
posted on 14/5/05 at 04:49 PM Reply With Quote
Here Northy. Somewhere in that thread he mentions it. http://www.locostbuilders.co.uk/viewthread.php?tid=21808&page=1
Thanks for the tips Mix. I found your other post with your pics. It looks great! That helped me out alot and will be very valueable during constuction.
Also, i'm using a 13b rotary engine. They are pretty small but I might have to change the intake abit.
Thanks again Mix, good thing I didnt start cutting!
Ditch the wife!
Mix
posted on 14/5/05 at 05:30 PM Reply With Quote
Graham
Yes I've got drawings, can you read either autocad or turbocad format?
Mick
Northy
posted on 14/5/05 at 05:57 PM Reply With Quote
AutoCad would be great!
Graham
Mix
posted on 15/5/05 at 11:39 AM Reply With Quote
Here goes then.
Be gentle with me, I'm not a draughtsman and these are only working drawings, but they will give you an idea of what I'm doing.
Hope this works
Mick
Northy
posted on 15/5/05 at 11:51 AM Reply With Quote
I'll have to have a look at work tomorrow.
Graham
andyps
posted on 15/5/05 at 03:45 PM Reply With Quote
Mick, is there any chance you could convert them to pdf or soemthing so those of us without cad packages can have a look? Alternatively I will pay postage etc for a printed set.
Mix
posted on 15/5/05 at 03:50 PM Reply With Quote
I'm not too good with all this modern technology, I'll try and involve my son and see what we can come up with.
Mick
Or alternatively if anyone could give me any pointers.....
[Edited on 15/5/05 by Mix]
Northy
posted on 16/5/05 at 05:07 PM Reply With Quote
I can do it at work tomorrow if you can wait....
Graham
ned
posted on 16/5/05 at 05:14 PM Reply With Quote
you can get free .dwg readers on the www...
beware, I've got yellow skin
