New Topic New Reply
Author: Subject: Chassis width
Spottty
posted on 14/5/05 at 05:26 PM Reply With Quote
Chassis width
I have been doing some measuring and am curious on how much room I should leave between the wheel and the body.
If I build a book chassis I should have about 3 inches but If I build a +4 I will have about 1 inch.
Is this enough room or do I need the 3 inches?
Best thing to do for a build....
Ditch the wife!
niceperson709
posted on 15/5/05 at 01:55 AM Reply With Quote
The real clearance issue is the distance between the inside of the tyre and the trailing links of the rear suspension . so it will be important to have the wheels and tyres that you intend to use as you are laying out your build . (or at least their paramiters ) some builders have used rose joints and narower brackets on the body to give more clearance for the tyres . I know of a couple of builders here (in Australia) who had to have some coustom wheels made at great expense because of a lack of clearance. I hope this is helpfull
Best wishes
Iain
Best wishes IAIN
life is not the rehearsal , it's the show so don't sit there thinking about it DO IT NOW
http://iainseven.wordpress.com/
Spottty
posted on 15/5/05 at 02:36 AM Reply With Quote
Ohh, I should have said it was IRS. Sorry about that. So there will be no trailing arms, just A arms (well one will be a N) in the back.
Thanks for the tip though, I realy want to get the rims first but the rim money pays for the begining of the chassis build. Oh the delema
Ditch the wife!
niceperson709
posted on 15/5/05 at 02:52 AM Reply With Quote
Hi Spotty
well the same things are important that the wheels and tyres do not touch the body or chassis as they move up and down , Can you get a wheel of the same size / offsett as those you intend to use or even borrow one ? even if it is a bit different if you know what the diffence is then you can check your clearance ,any way a bit more for you to consider
best wishes
Iain
Best wishes IAIN
Spottty
posted on 15/5/05 at 03:53 AM Reply With Quote
I would love to get just one rim to see if it would work but they are 15x7 with 0 offset so finding them too borrow is tough.
It looks like I will just have to build a stock chassis. I was hoping for the extra room but whats 2 inches in each seat area? Besides, now I dont need seats with leg support
Ditch the wife!
niceperson709
posted on 15/5/05 at 04:07 AM Reply With Quote
Hi Spotty.
You may be able to gain some room width wise in your cockpit by slimming down the transmission tunnel especially as you are going with IRS have you considered having some steel folded to make the trans tunnel you could very easily get 2inches that way maybe even more .Remenber that with IRS you do not have to allow for movement of the drive shaft . a folded and welded steel tunnel will contibute as much to chassis stiffness as the book design. just a thought
best wishes
Iain
Best wishes IAIN
Spottty
posted on 15/5/05 at 04:43 AM Reply With Quote
Hey, thats a great idea! The drivshaft is pretty small too. I'll just have to put in some bracing for the just incase it breaks moment.
Thanks again, I think the book chassis should do fine.
Ditch the wife!
New Topic New Reply
