Author: Subject: Which distributor?
david duncan
posted on 19/5/05 at 02:17 PM Reply With Quote
Which distributor?
When fitting carbs to an XE,which distributor should i use?
Stu16v
posted on 20/5/05 at 06:19 PM Reply With Quote
A Bosch one off any 8v VX engine, which has the same dizzy drive as the one in the end of your 16v at present...
Dont forget to get the coil and amplifier too, and a chunk of thw wiring.
HTH Stu.
Stuart Ainslie
posted on 20/5/05 at 06:25 PM Reply With Quote
I'm not bothering with a dizzy.
Using Megajolt with a Ford EDIS pack - Fully mappable
Phil. S
posted on 23/5/05 at 10:04 PM Reply With Quote
Have you seen this one on ebay?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=7975766858&rd=1&sspagename=STRK%3AMEWA%3AIT&rd=1
