Humbug
posted on 5/7/05 at 03:15 PM |
Boot cover and lid
I've just finished making the cover for my boot space, incorporating a lid (one photo here, more in my archive).
Cardboard template, then 3mm ali sheet cut to size. Main part cut in 2 so as to avoid hassle fitting it in place.
Cutouts for roll bar tubes done with hole cutter, spare bits saved to make infills
All pieces covered with foam - I got it for the tunnel top and had some left over - then black vinyl, all stuck with spray adhesive.
Holes for hinges drilled (carefully!) after sticking on the vinyl. Hinges came from a record deck and incorporate self-closing springs. Rivets should
not show on the top side as long as nobody pushes down on them
Any thoughts on:
How to fix? I would like to avoid rivets if possible, to keep the clean look. Alternatives would seem to be double sided sticky foam tape (will it be
strong enough?) or PU, which should stick OK but may be a bit permanent
Edging - do you think I need some edging (e.g. U channel) round the edges for SVA?
Boot lid - do I need a catch/lock? I hope the self closing spring thingies on the hinges will keep the lid more or less in place. What about velcro
strips, or would they come off too easily.
jonbeedle
posted on 5/7/05 at 03:48 PM |
I hate to say this but I think your lights are in the wrong place. I made that error myself. As far as I know they should be on the rear wings to pass
the SVA.
Jon
"Everyone is entitled to an opinion however stupid!"
Humbug
posted on 5/7/05 at 04:04 PM |
the SVA.
Jon
I hope not... I have read the lighting section of the SVA manual several times and it says the lights must be max 400mm from the outer edge of the
car. My car has a live axle and fairly narrow rear wings, so the nearest edge of the lights is about 350mm from the edge of the car
jonbeedle
posted on 5/7/05 at 04:28 PM |
I hope you're right. It would be a shame to mess up that nice paintwork.
All the best
Jon
the SVA.
Jon
Humbug
posted on 5/7/05 at 04:42 PM |
cheers - fingers crossed
Marcus
posted on 5/7/05 at 08:35 PM |
My entire rear cover is held on with velcro - stays on quite happily at 90
Marcus
Marcus
Because kits are for girls!!
Humbug
posted on 5/7/05 at 09:18 PM |
on a track or a private road only, right!
that's useful to know - I might try that.
Jon Bradbury
posted on 6/7/05 at 06:45 PM |
Bootlid + Velcro = SVA fail point
It (SVA manual) states that opening panels need to be capable of being "securely latched" which implies a mechanical locking device.
Certainly my car failed on Velcro at Southampton SVA last month, despite it being very secure at speed. I would suggest using one of the folding seat
retaining latches off the Sierra with a cable pull for SVA. The interior of the boot is exempt from projection testing so no need to contrive a cover
for it.
There are people who have got away with Velcro but I'd suggest leaving nothing to chance.
As to your rear light units, I think they're OK as long as they are no more than 400mm inboard (measure from the inside edge of the lamp unit to
be safe) and at least 500mm apart (unless your car is less than 1.4M wide in which case minimum separation is 400mm)... phew!
I like your paint!
[Edited on 6/7/05 by Jon Bradbury]
Humbug
posted on 6/7/05 at 08:44 PM |
quote: I like your paint!
Actually gel coat covered with a special blend of garage dust
