darrens
posted on 22/8/05 at 06:33 PM |
Nylocs & threads
I'm raking through the SVA book here and can't find any ref to it.
Does anyone know if the there is a figure on how many threads should be visable when using nylocs
I take it if it's flush with top of nut that aint good enough.
Darren
posted on 22/8/05 at 06:34 PM |
i cant remember if its 2 or 3 threads, or the shaft diameter that must protrude. Probably works out similar in the end.
SixedUp
posted on 22/8/05 at 06:49 PM |
No personal experience, but everything I've heard is that they look for at least two threads.
Richard
darrens
posted on 22/8/05 at 06:56 PM |
rate that'll do, might as well be on safe side
omega 24 v6
posted on 22/8/05 at 08:17 PM |
I would say 2 threads as well. Std engineering practice is usually 2 for visual check. Anyway 100mm of bolt in fresh air mucks up the power to weight
ratio
Marcus
posted on 22/8/05 at 08:23 PM |
I had probs at SVA for number of threads protruding, in the end, I found some nyloc half nuts - sorted.
Marcus
Marcus
Because kits are for girls!!
wicket
posted on 22/8/05 at 08:27 PM |
In order to get the magical 2/3 threads showing is it OK to use HT type T nylocs, which are thinner than standard, on suspension bolts.
