Author: Subject: Whats a De Dion??
Kieran
posted on 31/8/05 at 10:14 PM Reply With Quote
Whats a De Dion??
Hello, Im new. Whats a De dion axle set uplook like? Is it possible to use the sierra trailing arms (ala Pilgrim sumo) to give IRS??
Kieran
Chris_R
posted on 31/8/05 at 10:32 PM Reply With Quote
This is a De Dion axel, Sierra half-shafts and tranny courtesy of GTS Tuning...
Check out answer.com for an explaination.
A bit of slapstick never hurt anyone.
http://www.chris.renney.dsl.pipex.com/
DarrenW
posted on 1/9/05 at 08:52 AM Reply With Quote
Dedion is a funny old fashioned thing that vintage cars used to use!
Kieran
posted on 1/9/05 at 10:10 AM Reply With Quote
Has anyone used the trailing arms from a sierra / granada sun frame. Pilgrim pivet these to give IRS on their Sumo. Why hasn't anyone done it with a locost??
Kieran
Gav
posted on 1/9/05 at 10:35 AM Reply With Quote
i suspect that might be rather heavy for a lightweight locost 7.
The Sumo, isnt that the cobra replica? ie its gonna have a stonking great v8 in it
chrisg
posted on 1/9/05 at 11:00 AM Reply With Quote
Kieran
Erm... the ends of the trailing arms would be where your arse wants to be still I suppose you could pad them with some foam, you know, make a feature of them
Chris
posted on 1/9/05 at 12:25 PM Reply With Quote
Kieran
I think Joel used them in his first design. Robin Hood also use them in their 2B and Tiger use them in their Tiger Cat E1.
The rear subframe assembly from the Sierra initialy looks like it might save a lot of work, but it will require considerable chassis mods to fit, and it is very, very heavy, and also too wide. If you look at the RH and the Tiger you will see the ugly bulges in the rear wings where the subframe assembly sticks outside of the chassis. Avoid it and stick with either a live axle, de-dion or IRS as used by MK, Luego, MNR etc.
posted on 1/9/05 at 02:06 PM Reply With Quote
Kieran
Press on in an early 3 or 5 series BMW in the wet and find out why ;-)
posted on 2/9/05 at 05:35 PM Reply With Quote
Yes, i did and its poor. Its made the back end too long (cos i mounted the rubber thingy behind the seats rather than in them). Its got funny wheel geometry, and does indeed weigh a lot.
Avoid would be my advice
Avoneer
posted on 3/9/05 at 11:34 AM Reply With Quote
And is very low isn't it Joel!
Pat...
