pdw709
posted on 5/9/05 at 02:30 PM |
Headlights doing funny things...
Last night I noticed that my headlights have stopped working. I say stopped, but they are doing funny things.....
When I have them turned on with the engine, they are very faint. When I turn the engine off they remain faint, until eventually they dim and go out.
They then refuse to light up whilst the engine is turned off.
Wierd. Any ideas?
Phil
posted on 5/9/05 at 02:44 PM |
I'd start off by checking for bad joints, and particularly for bad earths.
If you've used a relay for the headlights then I'd consider swapping it for another.
If you didn't use a relay then I'd check the switch! (Sierra column switches don't have much current carrying capacity - they were
designed for relays originally, I believe).
posted on 5/9/05 at 02:58 PM |
AS DJ says really... sounds like a bad earth or switch that's burnt out if you haven't used relays.
It initially sounded like a battery fault but if your engine starts ok then that can be ruled out.
First things first:
- Earth Straps specifically related to headlights. Make sure all clean and well connected.
- Switch contacts - check integrity
- Relay function (if used)
Nice car BTW!!!
[Edited on 5-9-05 by Hellfire]
pdw709
posted on 5/9/05 at 03:15 PM |
Thanks.
Sounds like its must be either the Relay or the Earth. I'll have a closer look tonight.
Phil
posted on 5/9/05 at 06:38 PM |
BTW: If it helps, it sounds like you have a "nearly connection" somewhere - something that seems to be conducting OK, but goes
high-resistance due to dirt or similar.
I would look for a loose connector (it's on, but can be pulled off easily), a badly-made spade connector, a relay that's gone
'light' on the contacts, or switch in the same state.
You might get good results when testing with a meter or small test bulb, but not find this kind of thing - look for good mechanically sound joints.
Have fun!
tom_loughlin
posted on 5/9/05 at 09:17 PM |
something that made my headlights very odd was the earth above the light switch - where there are 23 spade connectors perpendicular to each other -
the one closest to the hazard switch is the heasdlights, the other is wipers unless im mistaken.
it was a long time till i found that out - but such a good feeling when everything works ok.
Just got back from my first night drive, bit foggy, but made it a little more interesting.
Tom
posted on 5/9/05 at 11:00 PM |
After it had been out in the rain my hazard switch illuminates the ignition and oil lights. I'd thought of calling in an exorcist.
