RobC
posted on 6/9/05 at 09:41 PM |
zetec breather?
can anyone shed anylight on what I am meant to do with this? cannot find any details on it and I don't understand what I am meant to do. Blank
it off / refit the original part / replace it with something else. And if I do refit where does the single pipe go to?
Many thanks for any help, as I am near the end of the build and its one job I have been putting off.
![](/images//smilies/sad.gif)
big_wasa
posted on 6/9/05 at 09:47 PM |
I refited the smaller unit from a 1.8 along with the valve ,im venting this to a catch tank along with the breather on the rocker cover...
Thats the plan anyway...
![](/galpreviews/) ![](/gallery/)
RobC
posted on 6/9/05 at 09:51 PM |
very tidy.
Just wanted to check, did you buy a new unit? or reuse the original. My engine was originally an auto and the breather looks different to yours. Might
get another from Ford parts.
Anyone know if these are interchangable? and best way to fit pipe?
big_wasa
posted on 6/9/05 at 09:57 PM |
the one on mine also automatic was huge so I fitted one I had from a 1,8 manual.It looks new because I shot-blast it then sprayed it up,fitted it with
ss cap screws...
warren
RobC
posted on 6/9/05 at 10:04 PM |
sorry bit dim tonight whats ss?
bob
posted on 6/9/05 at 10:12 PM |
stainless steel
RobC
posted on 6/9/05 at 10:53 PM |
duh.
Cheers buddy, off to ford parts tomorrow.
Many thanks for the help ![](/images//smilies/smile.gif)
Danozeman
posted on 7/9/05 at 05:59 AM |
Good job i read this. I nearly binned mine the other day!!
Dan
bob
posted on 7/9/05 at 06:41 AM |
Doh!!!! i had a quick look in the garage and cant find mine either,looks like its a trip to the scrappies again.
zetec
posted on 7/9/05 at 06:47 AM |
Just a note...The valve on the block is used when connected to the original inlet manifold and will normally open only when there is a negative
presure. This means that when connected to a catch tank it should never open, and so in theory could be blanked off or just left unconnected. That
said there is no harm in connecting it if you are fitting a tank for the camcover breather.
lsdweb
posted on 7/9/05 at 07:10 AM |
Guys
I spoke to Paul Dunnell when I was trying to sort my breather out - he recommends just blanking it off - the standard valve will do just that if you
just feed it into a catch tank as it needs negative pressure to open.
I made a plate by copying the gasket and fitted that.
Regards
Wyn
bob
posted on 7/9/05 at 08:30 AM |
Thanks for the info lads i thought i had seen a pic in the photo archive somewhere with a blanking plate on.
Danozeman
posted on 7/9/05 at 03:27 PM |
Sorry to be thick. Does this mean blank the one on the block and vent the cam cover one to a tank?
Dan
bob
posted on 7/9/05 at 05:07 PM |
I robbed this pic from andy hardings archive.
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=IMG_0017.gif
big_wasa
posted on 7/9/05 at 08:35 PM |
erm does that mean the rocker does the breathing for the whole motor ?
RobC
posted on 7/9/05 at 09:05 PM |
I am glad I asked now.
Cheers guys
lsdweb
posted on 7/9/05 at 09:13 PM |
Yes
The cam cover breather is, apparently, sufficient.
Wyn
big_wasa
posted on 8/9/05 at 06:55 PM |
Cheers guys
Im glad I replied learn somthing new every day![](/images//smilies/bigsmile.gif)
big_wasa
posted on 9/9/05 at 11:16 AM |
Sorted Made the cover quicker than it took me to tart up the old unit....
Aboardman
posted on 9/9/05 at 05:49 PM |
silly question.
I want to check that the breather on my zetec is not blocked.
have undone the singe bolt on the breather, but when i try to pull on the plate it starts to bend, have i missed a bolt?
or does it need a screwdriver to get off.
regards
Andrew
big_wasa
posted on 9/9/05 at 10:33 PM |
3 bolts hold it on. 1 through the middle and 2 on the backing plate.
if its blocked you can have mine,Its been tarted up.Yours for free as ive blanked it of.
