Avoneer
posted on 22/9/05 at 09:34 PM |
My new BEC prop
For those of you who have asked:
My prop was from Dunning and Fairbank.
http://www.propshafts.co.uk/
It's two piece with a torque resiliant tube and sliding rear section.
And cost me £165.00.
They can make any prop to your spec with any flange on either end.
Nowt to do with me, just a satisfied customer, especially for the price.
Pat...
chrisf
posted on 22/9/05 at 09:54 PM |
Pat:
Do you have a detailed pic of the TRT section of the prop? I'm nearing the need to purchase one and keep reading of the glories of the TRT--yet
have never seen one myself. Any help is appreciated!
--Chris
pathfinder
posted on 22/9/05 at 09:57 PM |
That’s just what I’m after and the price is right! Is it made from all new parts or did u supply a donor prop for butchering?
Avoneer
posted on 22/9/05 at 10:05 PM |
It's all new parts and I didn't have to supply anything apart from the length, flange size etc.
The TRT is just after the centre bearing and looks like a small tube going into the main prop tube and firmly mounted with rubber, but it's a
bit hard to see.
Send them an email!
Pat...
chrisf
posted on 22/9/05 at 10:10 PM |
Send them an email!
I think I shall! At that price, I could import it to the US and still save quite a bit. I take it that you got standard pricing?
tadltd
posted on 22/9/05 at 10:20 PM |
You could probably knock 17.5% off that price (UK VAT)...
..but add USA duty & taxes...
Best Regards,
Steve.
www.turnerautosport.com
chrisf
posted on 22/9/05 at 10:23 PM |
...and postage. But it is still a great price!
Pat:
How did you determine where to put your center bearing? How accurate were you with your measurements?
--Thanks for the help thus far, Chris
Avoneer
posted on 22/9/05 at 10:44 PM |
Hi Chris.
I welded a 6mm vertical plate opposite where my shin would be and measured from the centre of this plate to the prop adaptor face on the engine and
from this cenre line to the flange face on the diff.
My dimension were + & - 1mm and were fine.
No harm in sending them an email.
Pat...
Winston Todge
posted on 22/9/05 at 11:22 PM |
Thanks for the info Pat!
Chris.
robertwa
posted on 23/9/05 at 12:53 AM |
Chris,
Looking at the prop I got from my celica donor, it seems to be made with a TRT. Outer sleeve bonded to rubber, then bonded to inner sleeve.
Isn't that what a TRT is?
Winston Todge
posted on 23/9/05 at 01:03 AM |
That's what I understand of a TRT yes Robert. I'm sure Pat will clarify.
It works similarly to a cush drive on a motorbike to reduce vibration and dampen out jerkiness (is that a word?). From what I hear it makes a huge
difference to the driveability of BECs on and off the throttle at low speeds...
Chris.
jambojeef
posted on 26/9/05 at 10:04 AM |
Pat,
Did they specify having the centre bearing in the front section of the prop?
Only my donor prop has the centre bearing in the rear section and I just wondered whether there was any difference from a reliability/safety
standpoint?
Geoff
Avoneer
posted on 26/9/05 at 11:12 AM |
TRT - No idea how it works and how it's made, just asked for it as I've heard BEC need them.
Centre Bearing - No idea, I just told them where I wanted it in relation to the vertical plate on my chassis.
Hope that doesn't help!
Pat...
Coose
posted on 26/9/05 at 04:03 PM |
TRT is like a large metallastic bush. I first had my R1 prop shaft made (by D&F) without one, but then had one retro-fitted about 2 months ago....
What a difference! It still clunks a bit at low speed, but nothing like as bad as it was!!!!
I would highly recommend one.....
(D&F are nothing to do with me also - just another happy customer!)
Spin 'er off Well...
