Author: Subject: Car Prep
xxx
posted on 11/10/05 at 02:17 PM Reply With Quote
Car Prep
Hi guys basically im looking at buying a built road going locost and prepairing it for races. It already has a 1.3 x-flow. Is there any issues that I should consider before making the expensive plunge!
It has a safety cut off switch
It has a reinforced back roll hoop, is the front bit complusory (if so where can I get one)?
Seat and harness standard fia spec?
What are the current tyres required for the seires!
Colin
andyd
posted on 11/10/05 at 02:35 PM Reply With Quote
Go here and click the racing button at the top, choose regulations from the menu then click on the locost section. You'll get a PDF file with all you need to know.
