Author: Subject: 4age timing pulley removal?
shades
posted on 12/10/05 at 08:56 PM Reply With Quote
Has anyone got any tips on removing the Crankshaft timing belt pulley? My puller is too big... Also where can i get a new one from as I have now broken the backplate edge trying to pry it off with a lever?
I'm trying to fit a new oil pump and need this pulley off if you are wondering...
Ben Smith
posted on 12/10/05 at 11:27 PM Reply With Quote
A slide hammer works well. They can be VERY tight though.
Ben.
albertz
posted on 13/10/05 at 06:47 AM Reply With Quote
I have encountered the same problem with that b@$tard pulley. I have tried soaking it in WD40 for nights to no avail.
In the end i just had to hammer to off and find a relacement. The edges chip so easliy that one wrong move and its knackered anyway, once that happens it has to come off one way or another.....
shades
posted on 13/10/05 at 07:54 AM Reply With Quote
Hmmm I have broken the edges too. Where did you get a new one from? Is it a dealer part?
zzrpowerd-locost
posted on 17/10/05 at 08:06 PM Reply With Quote
if its buggered anyway, a good quality and sized cold chissel in between the teeth on the pulley and a good hammer shoud split it
