Author: Subject: Rear discs versus drums - weights
lsdweb
posted on 25/10/05 at 02:31 PM Reply With Quote
I'm just completing my rear caliper conversion and thought I'd post the comparable weights of the drum versus disc setups.
Drums (per side)
Backplate and cylinder - 1700g
Drum - 3200g
Shoes and other bits - 900g
Total - 5.8Kg
Discs and calipers (per side)
Caliper and bolts - 2000g
Pads - 400g
Disc - 3400g
Caliper brackets - 200g
Total - 6.05kg
The new handbrake cables should be lighter as I'll be ditching the interconnecting steel rod so I'm hopng the weight difference will be insignificant.
Regards
Wyn
gutball
posted on 25/10/05 at 02:48 PM Reply With Quote
Interesting!
Sierra right? Which drums do you have, 8 or 9 inch? There's only one type of Sierra rear disk isnt there (from "normal" models, i.e. not XR,cossie etc)?
wilkingj
posted on 25/10/05 at 04:20 PM Reply With Quote
Not a lot in it is there :
So little, that I would prefer to have the discs regardless of the difference. I would just loose a few Lbs to compensate.. ie a quick diet job!.
Best Regards
Geoff
http://www.v8viento.co.uk
posted on 25/10/05 at 05:00 PM Reply With Quote
Why so keen on discs on the rear? They sure won't help you stop faster, just look better maybe.
zetec
posted on 25/10/05 at 05:53 PM Reply With Quote
If I did it again I would be tempted by drums. I might be wrong but I suspect you can fit 13" wheels which is not an option with discs. Also of all the cars I have the handbrake is far better when working on a drum brake, iIsuspect because of the mechanical advantage the shoes give that you do not get with pads.
Don't worry about them over heating as the standard fronts don't even get near there limits.
highspeeddirt
posted on 25/10/05 at 06:41 PM Reply With Quote
I used 8" drums because of the ease of seting up the handbrake and also I didn't think there was going to be any advantage on the road of using discs. But the main thing has to be the relative cost of discs verses drums. With the money I saved at the back I've bought Hi spec ali 4 pots with lightweight discs and ali hubs for the front, where most of the braking is being done anyway. I have also saved weight over the standard escort brakes/hubs.
tks
posted on 25/10/05 at 07:50 PM Reply With Quote
whats cheaper?
shoes or pads?
discs or drums?
handbrake is far better on disc as on drums! my handbrake equals the brake power on the rear!
flak monkey
posted on 25/10/05 at 07:54 PM Reply With Quote
Drums are cheaper. Calipers for the back end of a sierra are very expensive if you are fitting recon units.
Pads and shoes are the same price within a few pence
Drums themselves are £20 each and discs £13
Calipers are £55 each
Cylinders are £7 each.
Overall drums are cheaper. And as has been said before there is not a lot of point in fitting discs on the back sonce you then also have to fit a regulator valve to stop the wheels locking too early as well.
The only reason I would end up with discs is if i fitted an LSD...
Sera
http://www.motosera.com
lsdweb
posted on 25/10/05 at 07:59 PM Reply With Quote
Live axle (English) rear end.
Costs - Peugot 206 - calipers - £45
pads - £12
Discs - Escort FWD (Incl machining) - £32
Brackets (CNC) - £50
Handbrake cables (206) - £21
Other bits / hoses - £20 approx
Fit very nicely under 13" wheels with loads of space to spare!
I wanted the more responsive braking offerred by discs / calipers without a major weight penalty - result!
Wyn
liam.mccaffrey
posted on 25/10/05 at 08:57 PM Reply With Quote
hows the throttle boddies coming wyn?
i was due in your neck of the woods tomorrow for a meeting but i've got some kind of infection/flu thing
Build Blog
Build Photo Album
lsdweb
posted on 25/10/05 at 09:34 PM Reply With Quote
Hi Liam
Still waiting for my manifold etc back from Altiss Engineering - it's been a while and I'm getting a bit nervous although he seems a genuine guy!
I'm slowly getting the bits together - just waiting for a mate to make the swirl/collector pot and I can start plumbing and wiring it all in.
How are you getting on - any progress?
Feel free to call and see me, but not with any flu symptoms!
Regards
Wyn
posted on 25/10/05 at 09:44 PM Reply With Quote
id use the 4 bolt hub carrier with a disc brake back end but no discs or calpiers, and use inboard brakes with an LSD its quite easy to set up with the bolt on shafts.
NS Dev
posted on 25/10/05 at 09:55 PM Reply With Quote
I'd rather have the few kg extra weight than p155 about with effing shite drums to be honest.
nothing wrong with the braking, they are just crap to work on, I hate the damn things!
liam.mccaffrey
posted on 26/10/05 at 08:03 AM Reply With Quote
going pretty well to be honest wyn, i decided not to buy a kit in the end and brave a scratch build. (despite your advice llys y fran last year). I had collected so many bits whilst i was in uni it seemed silly to go and buy a kit.
I have set up my lathe as a tube notcher and i have a friendly tube bender near me. So i am hoping to do quite a high quality job. Only thing i am having problems with is finding a reaonable CNC place for brackets and the like. You mentioned you used CNC for you brackets and it cost you £50 quid. How much do you get for £50. I'm a draughtsman so drawing parts is a nice distraction from work
Build Blog
Build Photo Album
lsdweb
posted on 26/10/05 at 02:23 PM Reply With Quote
Brave man Liam!
£50 got me the brackets from Trident Engineering (Sponsors of the Welsh Sprint & Hilclimb Championship and fellow competitors) but I could have got them cheaper if I'd have understood a bit more about the process, as I could have drawn it all up using coordinates which would have saved them redrawing it all!
I've posted some photos of the caliper conversion in my photo archive.
RichieC
posted on 2/11/05 at 07:23 PM Reply With Quote
Interesting stuff, I agree the only reason I see is fitting an LSD.
How much would be involved in fitting an LSD with drums at the back? Apart from rebulding the LSD into a different diff, can the shafts be altered?
Rgds
Rich
flak monkey
posted on 2/11/05 at 07:26 PM Reply With Quote
Rgds
Rich
You could chop the shafts for the lsd and normal diff in half and weld them together using a sleeve. however that job is probably best left to a profesional welder! Also I'm not sure if the shafts are the same diameter
Sera
