Author: Subject: rover engine?
paul_mcq
posted on 29/10/05 at 09:37 PM Reply With Quote
rover engine?
hows it going? just a wee question, the rover 220 turbo engine ( t series i think) is there a bellhousing or a box that it would fit to to make it rear wheel drive? cheers for looking. later
robinbastd
posted on 29/10/05 at 09:39 PM Reply With Quote
Very well,thank you.
http://smuttygifts.com/
Triton
posted on 29/10/05 at 09:43 PM Reply With Quote
don't mind if i do
www.tritonraceseats.com
www.hairyhedgehog.com
joolsmi16
posted on 29/10/05 at 09:57 PM Reply With Quote
t series
Robin hood, uses either the T5 or MT75 on the T series in there super.
I think a adaptor plate is used but unsure on method, have you looked at LT77 or R380 boxes just may fit.
Jools
scotty g
posted on 30/10/05 at 08:18 AM Reply With Quote
Robinhood use the MT75 box and cut it about until it fits, its not the most proffesional looking job but it does seem to work. I don't know if they would sell to a non Superspec customer or not.
Why do you want to use the t-series, its not the best motor out there and it is quite tall for a 7-esque car.
The Superspec is considerably bigger than a Locost.
posted on 30/10/05 at 08:24 AM Reply With Quote
Didn't PPC cover fitting this engine into a MGB? think they used an LDV bell housing ?
paulf
posted on 30/10/05 at 09:37 AM Reply With Quote
I would of thought it might connect to an MGB box as it is basically the same block as the B series ie very heavy.Maybe by using a backplate from a B series engine.
I had considered it but a zetec and type 9 box is far easier and lighter for the same or more power.
Paul
davidwag
posted on 30/10/05 at 10:13 AM Reply With Quote
AFAIK the T series engine is based on the old O series engine.
You could use the Marina/Ital or Sherpa/LDV Gearbox.
I seem to remember seeing a rapid marina with one of these engines at a track day at castle coombe a few years back. Gave the Escort boys something to think about.!!
posted on 30/10/05 at 12:08 PM Reply With Quote
Sherpa 2 litre petrol backplate, starter, flywheel and clutch apparently it must be the 2 litre the 1.7 won't do --- SD1 gearbox much better ratios than the Sherpa,.
Alternatively Rover SD1 2litre back plate flywheel, clutch, starter, gearbox -- ricking horse droppins.
It is possible the bits off a Sherpa Prima diesel might also work.
[Edited on 30/10/05 by britishtrident]
stevebubs
posted on 30/10/05 at 03:45 PM Reply With Quote
hmm.
http://club.triumph.org.uk/cgi-bin/blah/Blah.pl?b=dol,m=1124225014,s=all
