RichieC
posted on 31/10/05 at 10:08 AM |
Diff/Shafts etc - Drum vs Disc
Morning all,
Stumbled across a cheap XR4 rear end with diff, shafts and discs/calipers.
Is there much advantage or hassle by gong for this route?
I was happy with drums but this way I benefit from an LSD into the bargain.
Alternatively, can you fit drums to the bolt on shafts which come with the LSD?
Rich
G.Man
posted on 31/10/05 at 10:19 AM |
I believe the hubs are different for drums and disks and are interchangeable...
Is it an XR4x4 or XR4? only the 4x4 has an LSD
Opinions are like backsides..
RichieC
posted on 31/10/05 at 10:22 AM |
Its a 4x4. Ill keep me beadies open but I think this is probably the best bet.
Thanks again
Rich
G.Man
posted on 31/10/05 at 10:36 AM |
Yeah go for it, has all the bits you need
Disks look far better behind alloys
smart51
posted on 31/10/05 at 10:42 AM |
I have an XR4x4 rear end. No problems. The hubs are the same on discs or drums. MNR do rear uprights to suit. Sierras with ABS have teeth cast
into the rear hub. These foul the upright and have to be turned off (for turned read angle grinder or file if no lathe available).
There's nothing wrong with rear discs and a recent thread here suggests that the weight penalty is only about a kilo if I remember correctly.
RichieC
posted on 31/10/05 at 10:44 AM |
Ok thats good news.
I always thought they look better too, but wasnt sure if they were compatible.
Rich
marc n
posted on 31/10/05 at 03:44 PM |
we can convert drums to discs but not the otherway round
best regards
marc
amalyos
posted on 31/10/05 at 04:40 PM |
quote: Originally posted by smart51
Sierras with ABS have teeth cast into the rear hub. These foul the upright and have to be turned off (for turned read angle grinder or file if no
lathe available).
I've got the ABS 4x4 rear end, how much has to be take off to clear the hubs?
RichieC
posted on 31/10/05 at 06:26 PM |
Bit of bad news, the XR4x4 (with leather interior, Konis etc) I was going to buy (for £250) has 4 knackered calipers which the guy says are not worth
rebuilding
The MOT/Tax are up so that leaves the problem of moving it the 80 miles.
Considering it was mostly the back end I was wanting, thats a shame.
Is there much else that can be taken from a 4x4? I appreciate the front uprights are different but I assume the column etc is fine.
Did seem a bit too good to be true
Rich
[Edited on 31/10/05 by RichieC]
mnr laptop
posted on 31/10/05 at 08:01 PM |
hi ritchie
the rack link is likely to be the wrong one as it will be power steering one which is cast, the column will be ok.
re the abs rings anyone who is building our cars we do this for you and will turn them down in the laith, it can of course be done by a grinder but
not as neat
best regards
marc
billy
posted on 31/10/05 at 08:15 PM |
Just a quick thought, if you put drums on the back just wait till you stand back and admire your car.........then you see those drums on display thro
your nice shiny wheels and you think my god they have got to go![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
luego-lo-cost finished,vauxhall 16v 2.0,twin 45s de-dion rear set up
RichieC
posted on 31/10/05 at 08:20 PM |
Cheers marc et al
Im not going to bother with this one I dont think. 160 mile round trip and a load of grief if these calipers are indeed knackered (it failed the MOT
on those alone)
Im sure another one will come along but as Im in no rush I will hang out for the right one.
XR4x4 back end I think, bog standard everything else.
Rgds
Rich
posted on 31/10/05 at 08:21 PM |
rebuilding
Rich
If its scrap, pay no more than £100. There isnt much of value on it - i sold loads of columns, switches, handbrakes, gearlevers etc for fivers and
tenners. Add in the time to break it, and its not such a good prospect. Leather makes it a bit better, but still bleak.
RichieC
posted on 31/10/05 at 08:25 PM |
Yeh quite agree, its becoming less worth it.
Rich
mnr laptop
posted on 31/10/05 at 08:28 PM |
we do some plates that adapt the drums to disc brakes, as using the drum brake shafts saves some weight
best regards
marc
RichieC
posted on 31/10/05 at 08:49 PM |
I see. So in terms of weight saving, for a rear brake setup youre better off with brake shafts and then adapting them.
I just need to work out which shafts (bolt/slip in) go with which brakes/diff combo........and there was me thinking there werent many differences
between Sierra models
What are your thoughts on 240 vs 260mm and Solid vs Plain for the fronts? I assume both types of caliper accept both sizes and i want the brakes to
be as good as they possibly can, but there seems to be a trade off with weight vs stopping power which i doubt needs to be that hairy on such a light
car.
Rgds
Rich
marc n
posted on 2/11/05 at 09:26 AM |
hi rich
even with 240s on the brakes are pretty good ( and they are cheaper for the pads recon calipers etc )
best regards
marc
RichieC
posted on 2/11/05 at 01:23 PM |
Great cheers, Ill just see what comes along.
Was I right in thinking that both sizes & the vented and solid fit the calipers?
Rgds
Rich
smart51
posted on 2/11/05 at 01:58 PM |
The vented discs are much wider than the solid (they are like 2 discs with a gap between them) you will need different calpipers for solid discs.
RichieC
posted on 2/11/05 at 02:03 PM |
Of course - what a numptie
Rich
smart51
posted on 2/11/05 at 06:47 PM |
Many people suggest that the solid discs are plenty for a light weight car. Do you really think that you'll need the extra braking force? Is
the extra unspring weight a price worth paying? Remember that all up a sierra could weigh nearly 4 times a bike engined vortx and only the high
performance versions had the big front discs.
RichieC
posted on 2/11/05 at 07:16 PM |
Yep, I agree, but if the donor you end up with has vented front discs, its a shame not to use them.
andy d (rizla)
posted on 2/11/05 at 08:10 PM |
i have vented front and solid rears on my vortx,
ive done a few track days and sprint races and they perform really well
id recomend them
Bryan Sears
posted on 2/11/05 at 09:21 PM |
So Marc can I use the 3.38 diff that I will have with the shafts that I took out of my donor that had a 3.92 diff both push fit and fit the rear disk
brakes and callipers from a 4x4 using the brackets that you make to convert drums to discs.
If anyone can understand this can you advise.
mnr laptop
posted on 3/11/05 at 09:39 PM |
hi brian thats correct
best regards
marc
