Avoneer
posted on 1/11/05 at 09:57 PM |
Nose cone SVA / Aerodynamic wings
Following on from this thread:
http://www.locostbuilders.co.uk/viewthread.php?tid=33538
I bent a 4" wide piece of ali to shape like a wave. Covered it in brown parcel tape and laid up two layers of 300g matt.
Once set, I pulled it all apart, trimmed it and ended up with this:
Really flexible, which I didn't expect and really hard to snap (as I tried with an offcut).
Pat...
![](/galpreviews/a276760-1.JPG) ![Rescued attachment 1.JPG](/gallery/a276760-1.JPG) Rescued attachment 1.JPG
Avoneer
posted on 1/11/05 at 09:58 PM |
Held onto car with tape:
![](/galpreviews/a276762-2.JPG) ![Rescued attachment 2.JPG](/gallery/a276762-2.JPG) Rescued attachment 2.JPG
Avoneer
And another pic:
![](/galpreviews/a276763-3.JPG) ![Rescued attachment 3.JPG](/gallery/a276763-3.JPG) Rescued attachment 3.JPG
Avoneer
posted on 1/11/05 at 10:01 PM |
Needs some fine fettling.
Really easy to make and trim to fit any nose and would require minimal body filler to make it smooth.
I reckon it could be even stuck on with polyurethane, but mine will be bonded on.
Pat...
Triton
posted on 1/11/05 at 10:30 PM |
Pat,
You will need to roll the edges so the sva man doesn't accidently slip and cut his arm off....bond those bits on ...when set...use plasticine
to create a nice return then glass up to that....when it's gone off pull the plasticine off and bingo....blob of filler to sort bumpy bits
www.tritonraceseats.com
www.hairyhedgehog.com
Avoneer
posted on 1/11/05 at 10:55 PM |
Or some nice rubber U trim ;-)
Will the glass/resin not stick to plasticine?
Pat...
Triton
posted on 1/11/05 at 11:08 PM |
Pat,
Nope won't stick.
Mark
Triton
posted on 1/11/05 at 11:13 PM |
Return edge would look neater Pat although you may still have to have edging on it for SVA.
Avoneer
posted on 1/11/05 at 11:17 PM |
Cheers Mark.
Watch this space as they say.
Pat...
Triton
posted on 1/11/05 at 11:23 PM |
Pat,
Before you stick them on....really badger the nosecone with a grinder around the area they fit to....then glass from behind and a wee bit on the
front....nice and strong then
Mark
derf
posted on 2/11/05 at 01:56 AM |
yes I plan on doing the same thing...
looks like ti turned out real nice too.
[Edited on 2/11/05 by derf]
RazMan
posted on 2/11/05 at 05:59 PM |
The packing tape dodge really works doesn't it. It saved me hours of work when I was doing my headlight transplant.
Coming on nicely Avoneer
[Edited on 3-11-05 by RazMan]
Raz
