Author: Subject: Advice please... Do i really need a cat ?
marcotuinenburg
posted on 13/11/05 at 09:51 AM Reply With Quote
Could you guys please give me some advice.
I'm building a 1999 fireblade engine model SC 33 with carbs in my MK.
I always thought every car with an engine that's from 1995 or later always needs a cat.
Yesterday a friend came by who ownes a Westfield, he told me i probably won't need a car because i'm using carbs.
Could you guys please give me some advice about this subject because i don't know if i can get the car through SVA without the cat.
G.Man
posted on 13/11/05 at 09:53 AM Reply With Quote
Cat is compulsory for engines after summat like 1995 I believe..
You May be able to pass the emissions without, but they are supposed to look for one fitted to minimise HC emissions...
Opinions are like backsides..
zetec
posted on 13/11/05 at 10:11 AM Reply With Quote
The very fact you are running carbs would make getting thru the SVA without a cat more tricky as they are not as easy to setup for low emissions. There are a few companies who will loan you a cat or sell cats which they say will get a carbed car thru the SVA. Using a air bleed system is another popular way to try and get emissions down.
tony9876
posted on 13/11/05 at 01:06 PM Reply With Quote
To be honest i have allways preffered dogs.
ReMan
posted on 13/11/05 at 03:17 PM Reply With Quote
Yes you will, speak to MK they may help you........
kb58
posted on 13/11/05 at 04:31 PM Reply With Quote
You *really* need to talk to someone in your country. Asking people here... asking me, who's in California, is going to give you all kinds of answers completely useless for your situation. Just contact your local agency and ask them; they're the ones who know, they're the ones who will test you.
And its book - http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
ReMan
posted on 13/11/05 at 04:56 PM Reply With Quote
The UK has the SVA, so presumably the car will be brought to the UK for an SVA else why ask the question?
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
dutchsuperseven
Builder
Posts 105
Registered 28/2/03
Location Born, Holland
Member Is Offline
Photo Archive Go!
Building: Locost-clone, powered by zetec 1.8, sierra type N9
posted on 13/11/05 at 05:20 PM Reply With Quote
Marco,
speak to Luc Haselier, he had a mk with a "blackburn Automotive"??? lambda-system on a motorcycle-engine. With this system and a cat you can pass the emission test.
The Lambda-reading should be 0.97-1.03, with a co of max 0.3% and HC of 200ppm max. at 2500-3000rpm, lika a normal dutch viergasmeting.
Groets, Rob
[Edited on 13/11/05 by dutchsuperseven]
Sex, drugs and Supersevens
tks
posted on 13/11/05 at 06:12 PM Reply With Quote
Where do all the dutch boys go?
Hey guys i'm aso dutch,
Where do we all go for the "sva" for our car???
On the RDW there isn't much info about the theme?
Do whe go to our neighbours? its an option but when entering holland we will need an re test anyway? Do we do the "individuele goedkeuring?"
Would like to hear from you all?
Walter
marcotuinenburg
posted on 13/11/05 at 06:37 PM Reply With Quote
Thanks for the help everyone.
Now i'm one step closer to get it on the road in Holland.
