Author: Subject: DURITE INDICATOR SWITCHES
kev R1
posted on 16/11/05 at 08:04 PM Reply With Quote
Can anyone help me out on this wiring diagram for my indicator switch, this wiring diagram is the one supplied with the switch and doesn't seem very helpful to me! Rescued attachment durite indicator switch.JPG
rayward
posted on 16/11/05 at 08:21 PM Reply With Quote
looks a bit odd, but i would say,
1 and 3 go to each side indicator circuits, and 2b is the feed from the flasher relay
7,8,9,10 not used
HTH
Ray
kev R1
posted on 16/11/05 at 08:23 PM Reply With Quote
yeah thats what i was thinking dont know why it shows the outer ones like that,
cheers
k33ts
posted on 16/11/05 at 08:29 PM Reply With Quote
you will only use 3,1 and 2b,
2b will be your supply from flasher relay.
3 and 1 to left and right indicators.
duno what the rest is bit of a naff diagram.
Chippy
posted on 17/11/05 at 12:48 AM Reply With Quote
Never come across this switch, one thing I would ask, does it have warning lamps built in, and if so are these the 7,8,9, and 10 connections, if so you would need to connect 1, and 3, through them. May be totaly wrong but worth a check. ATB
Martin van der Wal
posted on 17/11/05 at 05:54 AM Reply With Quote
Connect 1 to 10 and 3 to 9 , 7+8 to ground and the lights in the switch are flashing , when the switch is activated.
