Author: Subject: Bicycle speedo
chrisg
posted on 2/12/05 at 10:20 PM Reply With Quote
Bicycle speedo
I'm after some info on bicycle speedo's.
1. Do they have an odometer(mileometer)?
2. How do they detect the speed?
3.Will they pass the MOT?
4. what features are desireable for a Locost/seven?
5. any recommendations?
Any help appreciated.
Thanks in advance.
Chris
flak monkey
posted on 2/12/05 at 10:24 PM Reply With Quote
1. Yes
2. Reed switch (or proximity sensor) and magnet attached to wheel rim
3. Yes
4. Back lit, read to more than 99mph.
5. Cant remember the recommended ones off the top of my head.
Sera
http://www.motosera.com
miserableoldgit
posted on 2/12/05 at 10:27 PM Reply With Quote
Halfauds apparently sell a good one. Works onHall effect with magnets, smoke and mirrors.
Presumably you fix it to the wheel or propshaft depending on which is easier.
Youth and vitality are wasted on the young
chrisg
posted on 2/12/05 at 10:32 PM Reply With Quote
Thanks.
I might nip down to Halfords, using my shiny new discount card!
Thought of another question.
What voltage do they run on?
Can they be "Hard wired" to the car?
"2. Reed switch (or proximity sensor) and magnet attached to wheel rim "
is the sensor fixed to, say the wing stay?
How is the magnet fixed to the rim?
Sorry!
Chris
[Edited on 2/12/05 by chrisg]
zzrpowerd-locost
posted on 2/12/05 at 10:44 PM Reply With Quote
Cateye is a good make
Usually have one of those 3v "coin" batteries, last ages
flak monkey
posted on 2/12/05 at 10:48 PM Reply With Quote
Originally posted by chrisg
Thanks.
You can use araldite or something similar to glue the magnet to the rim.
The sensor needs to be very close to the magnet, i think there are a few people on here who have fitted them to the upright themselves.
And yes, voltage wise they usually run on a 3V lithium battery, which lasts for about 3 years on my bike!
Sera
posted on 2/12/05 at 10:57 PM Reply With Quote
We fitted a Sigma Chris. It read up to 99.9mph then started at O again (allegedly) but there are some that read up to 180mph. The magnet was JB welded to the rear rim and the wire extended with speaker cable. Sensor bracket was fastened to the bottom shock mount.
[Edited on 2/12/05 by Peteff]
Avoneer
posted on 2/12/05 at 11:40 PM Reply With Quote
I had my magnets on one of the CV joint bean cans on the back axles - worked a treat.
Pat...
MkIndy7
posted on 3/12/05 at 12:56 AM Reply With Quote
Some are wireless, and have the 3V cell in the display and in the sensor pick up.
Saves running yet another wire I suppose
trikerneil
posted on 3/12/05 at 07:48 AM Reply With Quote
I first fitted a Toppeak - looked lovely but the display was so complicated I had trouble actually telling what speed I was doing.
I'm now using a Halfraud's own brand, cost about £8 and works a treat. The backlight only works while you press the button so that's a problem for the MOT, I had to fit a light that illuminated the display.
Keep the wiring away from the ignition or you'll have a lottery number generator!
posted on 3/12/05 at 09:54 AM Reply With Quote
Some are wireless
I have a wireless one on my pushbike. They don't update fast enough for a car's acceleration and will not read accurately until the speed is constant.
skippad
posted on 3/12/05 at 11:05 AM Reply With Quote
One of the problems with bike speedo is when you are accelarating fairly rapidly...
display cant keep up until your at a steady speed.
They are ok until u can afford a digidash!!
paulf
posted on 3/12/05 at 11:59 AM Reply With Quote
I found the same with mine, i couldnt work out why i couldnt get 0 to 60 under 10 seconds but then tried using the main speedo and found it to be sub 7 secs, so ok for steady speeds and trip mileage average speed etc.
